  New Posts New Posts RSS Feed - Grooves in a scoop design!???
I-shen Soundboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 5:03pm
Originally posted by Youngculture89 Youngculture89 wrote:
i seen some will rebate joint all corners but not actually groove/dado along the side panels so the baffel section snugs in each side..seems like it will be more sturdy but also wont want to risk room for error. My bredrin has built many things just not speaker boxes and he suggest doing it. Also this method will take longer to complete scoops.... Seems like you guys think its a good idea.. Definatly would be more complex but end result would be legit?
Far more sturdy, and about three times more work than a glue and screw construction, which is why it isn't commonly found or alluded to on the plans.  No room for error, so measure thrice and have a sharp chisel handy for the test assembly.  Big sash clamps and a mallet will help pop everything into place.  Your man sounds like he knows what he's doing.
Full rebating may or may not have a measurably positive effect on sound quality, but improving the solidity of mid-panel joints (i.e. the baffle and internals) will reduce harmonics in the main panels far more effectively than rebating the edges alone, where harmonic resonance is lower.  Just my 2p's worth...
Edited by I-shen Soundboy - 23 September 2018 at 5:11pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 5:55pm
I fully rebate all my cabs, there are a few other uk builders that also fully rebate. I don't see any point in part rebating, if you gonna do the job do it right..
Youngculture89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 5:56pm
Give thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 6:24pm
give thanks for the advice . we are starting to work on them now.. Well see what happens๐Ÿ˜Ž.
๐Ÿ”Š๐Ÿ”Š๐Ÿ”Š๐Ÿ”ŠAlso anyone have a nice usb kick design for two 15s?? For the low mids.. Bless!
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 8:18pm
Originally posted by dj jammin dj jammin wrote:
Yeah its a good idea, pretty standard.. ive built boxes with and without rebate.. both work but the rebates provide physical location and also a litle extra contact area between the 2 pieces of ply
Some of the best cabs I've seen built by Mr Dj Jammin......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 8:43pm
bless ...
