Grounding Gear and UK Fuses |
Page <12 |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4794 |
Yes but I would throw those substandard IEC leads away. How much are genuine, certified 10A IEC leads from CPC...£2? Not worth risking your life or someone else's for this. Think of it as seeing your rack on fire for free or seeing it working fine all night for £2.
North Staffordshire |
fatfreddiescat ![]() Young Croc ![]() ![]() Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1020 |
I asked to take a look at a PC that wasn't working properly, when I touched the metal casing I got a minor shock, cheap IEC cable turned out to be made of conductive plastic.
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4194 |
Pray do tell... Pics or links or simply What's the mains power connector for this item ?
SnailSpace ![]() Registered User ![]() ![]() Joined: 08 December 2022 Status: Offline Points: 101 |
PDU
1U 6 way Horizontal 13A switched PDU with 3 Way LED indicator Surge protection.
SURGE PROTECTED - Surge protected devices are used to protect equipment from surges in voltage ensuring all connected devices are safe when connected. Provides 6 UK Sockets. Power Switch. 3 Pin UK plug (13 amps) (3X1.5mm2). Length of power lead is 5m. |
Ok there is only a 13a fuse in the plug for the 4 x 13a outlets. you can run the entire system off a single 13a plug (it might get warm) but it is better practice to spread the load across two supplies ie: use a separate 13a supply for your biggest amplifier and use the PDU for everything else.. |
I have x2 PDU. But yeah makes sense to put the Amps into their own wall socket. I have x2 double wall sockets at home so ill out large amps into those and have turntable, DSP, Siren, Mixer and (smaller) high amp in PDUs thanks
PS I’ve bought 10amp rated leads too, thanks for the advice people.
Page <12 |
