  New Posts New Posts RSS Feed - GS3 to led
GS3 to led
 Post Reply Post Reply Page  <12345 14>
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 2:49pm
They really need a thermometer for hotter ambient temps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 2:51pm
All done,  was rather tricky.  The sensor just needs milling into the heatsink close to the aluminium base as possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 2:53pm
I have also used some wire wool on the chrome fan covers,  they came up really well....
IainB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IainB Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 3:43pm
Im inspired, have 6 mini scans here that need a good going through (WAY too many projects on my hands atm)
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 5:13pm
Well dome that man!! I love you have thrown yourself into this and just kept hacking away until you got where you needed to be. I hope the end result is all you believe it will be... and keep us all posted we love pics of the fun you're having
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:13pm
Thanks guys.  It is fun and rewarding,  I'll try and take pics but I often forget in between bits
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:19pm
The second photo I took with the flash on as it doesnt come out as it looks.  The edges are clean and I'm pleased.  This is the 300w (575 replacement)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:29pm
After 40 mins it settled on 54.6 on full brightness.  The sensor is mounted right on the led aluminium base. The led die (part where electrons cross) is approx 70 degrees,  way below the 150 degree maximum.  The 100,000 hour lifetime spec is typically when the aluminium base is kept below 85 so it should last forever
