GS3 to led |
Post Reply | Page <1 678910 14> |
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 924 |
I'm not getting boards made up with tracks on initially as this is just a test and I don't currently have the facilities. I plan on using a sheet of PCB with holes cut in the same spaces with the non copper side face up as a spacer to give the gap that they currently have. I've cracked them off of the heatsink so i can split that up, once I've found a solid setting adhesive (like the one that is on the heatsink now) I can get this moving on and hard wire them to a flying lead with a 4 pin xlr and a socket sitting in the block where the lens was.
mini-mad
Steve20131
Registered User Joined: 28 July 2013 Location: Northants Status: Offline Points: 411 |
Hi, sorry for late replies. I drilled the baseplates through and used m2 bolts and copper grease/aluminium paste. Alumimium does'nt last that long if you tap it and have to remove them a few times while you work on it. Lux meter has come so can do some tests soon...
Good to see you all working on stuff keeping old units going
Steve20131
I know, I've sold an old project car to get these out the way...
Steve20131
Steve20131
Steve20131
Steve20131
Steve20131
Steve20131
Steve20131
This is a 200w cold white chip. The first colours and open white are in low power mode (last forever mode) the last white is full 200w.
Initially I was very dissapointed but after some head scratching I realised that the light meter went x10 / x100 automatically, and it was in x100 mode, so heres the results Low power 0 distance 7520 Lux 5m 1880 Lux High power 0 distance 11280 Lux 5m 2820 Lux The last photo shows the meter in x100 does'nt register ambient light
Steve20131
