  New Posts New Posts RSS Feed - GS3 to led
GS3 to led
 Post Reply Post Reply Page  <1 101112
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:20pm
Hi no the led is bolted with transfer paste inbetween.  You can use high temp epoxy but is a pain if you need to remove it (a chisel job).  I was going to use the cyanoacrylate with aluminium oxide the same way people use it with baking soda.  It will be strong and transfer heat.  The led with the right size sink wont get to 80c.  However to make sure I plan to braze it.  Might be easier than pop rivets..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:32pm
New box of led's to do all the other scans
Will have a crack at it all again at the end of the month....
Edited by Steve20131 - 09 April 2018 at 6:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 5:46am
Hi folks,   I've completely redesigned my plans it but it's too complicated to explain, I'll just take photos...
