G-SUB CUTSHEET |
Page <1 2345> |
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
or rebated?
RUS ![]() Old Croc ![]() Joined: 02 September 2008 Status: Offline Points: 3471 |
hay dub it is a plan for standard butt joint build it is to the exact plan of rogs is there anything in particular I can help you with ? |
Yes Rus if poss just want to check it to my cut list i did my self , butt joined
its probley me bro, not borthered about the internal bracing as we know some do it a little diffrent so just to keep it simple mine 670mm x 536mm x 2 (Top and Bottom) 618mm x 1100mm x 2 (Side Panels) 1100mm x 500mm x 1 (Back Panel) 490mm x 500mm x 2 (Front Baffle's) 500mm x 193mm x 2 (Shelf Ports) 193mm x 120mm x 3 (Port brace) Extra one for the middle, just my way Edited by Dub Specialist Sound - 16 April 2015 at 5:11pm |
Measurements as the box in standing up, as we know sme do as the box is lying down
nice one
why are your baffles 472mm
are you building them from the side of baffle or flush on the inside
just calulated it
your putting the port shelfs on the side of the baffles
so mine is correct littaly by the plan
hang on no im not lol i tied man lol
Dub stop talking to your self
![]() I've tried to work it out I think I understand some of what you did, you can give me the external dimensions of your box if you want and the meterial thickness and I can work out the litre box you have and compare it to the original I think your box dimensions are slightly smaller than the original plan, A lot of people seem to not add the side parts of the port making the port 36mm wider I don't know why they do this ![]() |
haha tell me about it Rus haha
i think ive got it now , what it is when i zoomed into the plan, i realised some put them ports shelfs on the inside of the baffle and some put it on the outside thus making the baffle dimesions a little size different, not the over all box dimensions of 1136 correct? cheers rus
yes got ya on the side port , making the port hole slighty larger , than on the plan
Yes the plan says to put the baffle butting up against the side of the port,
It's difficult for me to work it all out as I'm on a mobile phone with a small screen |
Page <1 2345> |
