guesstimates for home sub enclosure size |
Post Reply | Page 123> |
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1834 |
Posted: 07 December 2018 at 5:25pm |
wife acceptance has reared its ugly head once more and the 5.1 system in my sitting room needs to lose its current sub.
the only place I can really put its replacement will be under a coffee table. this gives me max external dimensions of 320x300x1220mm internally, before taking out driver, bracing, ports etc that gives me about 0.089m2 to play with. the 12" driver I have to play with didnt seem like a contender when I looked at it about ten years ago (ciare pw324 - ancient, no t/s available) but, since I had a couple of minutes spare I ran some signal through it and measured fs at 28hz. overall q seems lowish as there wasnt a huge change in measured voltage either side of resonance but since this has all been quick and dirty thats just a half educated guess looking at the cone movement it looks to have a higher xmax than previously expected so should I: build the box at the 0.089m2 Ive got available and tune to 20-25hz or build a sealed box at about 75% of that size and get all smiley on the eq so, given thats what Ive got to play with what do you think I should do
Edited by godathunder - 07 December 2018 at 5:26pm |
LOUDER THAN LOUD
cravings
Can't really offer any help, but I have 2 of those drivers too and have never known what to do with them. I was sure I once found parameters for them but I looked again relatively recently and couldn't find anything.
godathunder
someone posted up specs for me on here years ago which made it look more of a low mid driver but its physical appearance and fs seem more suited to the lower octaves.
Ive got some spare mdf lying around so I might as well knock up the largest box I can fit into the space then stick a couple of breezeblocks in to see if they seem happier in a smaller enclosure btw, Ive been meaning to hit you up for a coffee since I moved over here (4 years ago now - whoops)
LOUDER THAN LOUD
Ionkontrol
Registered User Joined: 15 February 2005 Location: Surbiton Status: Offline Points: 374 |
Always fancied doing one of the Decware coffee table subs.
Missus thought it was pretty shit as a storage device for a living room. She is right. Choose your battles......
cravings
yeah i was just gonna say are you still in wicklow.. so you are. i'm the south end of dublin. yeah would be good to touch base at some point alright.
yeah they look like pretty beefy drivers.. big coil and dustcap, big magnet. |
MattStolton
Anything on this site of assistance?
The man of x-over fame himself: http://www.linkwitzlab.com/thor-design.htm Edited by MattStolton - 08 December 2018 at 11:55am |
mini-mad
Folded 1/4 wave pipe?.... with a small flare.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
with that area you could build a really nice T line.
toastyghost
Properly documented and more importantly, properly measured and equalised! |
mini-mad
That's what I said... with slightly different words
concept-10
Aman Gebru
Registered User Joined: 01 February 2014 Location: Delhi Status: Offline Points: 350 |
