Handles for 1850 horns? |
singingfish
Registered User Joined: 25 October 2009 Status: Offline Points: 52 |
Posted: 01 May 2019 at 11:42pm |
Hi all.
I've got a pair of 1850 horns with PD1850s in and really nicely built. I love 'em. Has anyone managed to put handles in 1850s successfully? I have the cabs for gig work and eight handles in each would be ideal for handling as they are the weight of small moons. There's so much going on in the cabs though that I want to be very careful before going at them with the router jig. I built my own design tops to sit on them with Penn Elcom corner handles and was wondering if these could be used for these cabs to match. I like the way they look and they're great for ratchet strapping. These: |
colinmono
Young Croc Joined: 10 October 2007 Location: Midlands UK Status: Offline Points: 1111 |
Our 1850's only have handles at the mouth end... would be interested to know if anyone has tried putting them at the driver end. Handles placed at the driver end are going to protrude into the start of the horn path (opposite the driver). Sorry I can't really help with your question but will be following with interest...
colinmono
The looney bin (which I'm guessing used the same folding as the 1850 horn) had handles on the sides, which I guess wouldn't interfere with the horn path much. We move ours up and down stairs more often than I'd like, so not sure this solution would be the best for that case. |
snowflake
I think I have the same corner handles that you used - Penn Elcom H1105/90. I was going to use them on my new build but just noticed that they aren't airtight. they are made out of folded sheet, not stamped out of a single piece so there are eleven air leaks in each handle. Not sure whether to seal them all up or use a different handle. H102491 is manufactured differently from zinc and ABS plastic so I assume there wont be any holes in the corners. Also just clicked with me that to recess these corner handles you have to round over inside the recess after routering which is a PITA too.
