Harfield M2000 |
Post Reply | Page <123> |
TimmyP
Registered User Joined: 08 April 2009 Location: DARTFORD, UK Status: Offline Points: 22 |
Sorry, yes it is a 3U Amp. Perhaps I should have mentioned that sooner.
Cheers for your input Andy, still runs very well. regards Tim Pell |
kanks
Registered User Joined: 26 April 2012 Location: Manchester Status: Offline Points: 259 |
its the same as my 3u2000. with harfield m2000 on the front if memory serves me right
Kneal7
New Member Joined: 02 July 2013 Status: Offline Points: 4 |
Hi guys, we've recently aquired 2 Harfield M2000 power amps from a night club that had closed down... If anyone could post the specsof said amp I'd really appreciate it... I was also wondering how much do you think one of these ams would sell for. We have 2 so we might sell one...
Regards Kneal |
TimmyP
Hello Kneal,
I've had one of these for nearly 4 years now, I brought it second hand. Very heavy but very reliable, I use it for Dj'ing and have run it with the volume turned up to 11 with no problems on some very low impediances. I have been in touch with the forum member 'AndyAmp' it's one of his amplifiers. Originally made by Matrix and re-branded as a Harfield amp. It's rock Solid down to 2 Ohm's a side here are the specs. 2 x 1000 Watt RMS @ 2 ohms 2 x 550-600 Watt RMS @ 4 ohms 2 x 300-350 (ish) Watt RMS @ 8 ohms 1 x 2000 Watt RMS @ 4 ohms (Bridged) 1 x 1100 Watt RMS @ 8 ohms (Bridged)
Are you in the UK? I might be interested to take one off your hands then I could Bi-Amp my current setup rather than running a Mono Bridge. Regards Tim |
Kneal7
Thanks for the info Tim, really appreciate it.
Ive not paid for these amps, but ill let you know we're selling one. Regards Neil |
kedwardsleisure
rather nice robust amps these, didn't Matrix add a peak-hold meter to the Harfield versions?
North Staffordshire |
TimmyP
Yes indeed they did. I've never actually timed it but it's about a 3 second hold once you hit -3db on the meter.
wayward91
Young Croc Joined: 15 July 2010 Location: Leeds/Mancester Status: Offline Points: 676 |
you shall have to stick it on the internals thread , i might keep my eyes open for one :)
BigSoundNorthWest
Registered User Joined: 29 November 2014 Location: Manchester Status: Offline Points: 290 |
I have a 2u1000, does anyone know specs on it please ?
Wikl109
Young Croc Joined: 29 April 2009 Location: Yorkshire Status: Offline Points: 969 |
Yep, to quote the manual for said amp: 2U1000 Power Output: 550w 4ohm 300w 8ohm 1100w 8ohm bridged Input signal +4dbm 1.2v for rated output Damping factor greater than 300 ref 8ohms @ 1khz |
Cheers, Chris.
BigSoundNorthWest
Nice one mate, thank you.
samwhistler
New Member Joined: 21 December 2022 Location: Portsmouth Status: Offline Points: 2 |
Hi Chris My Name is Sam and I am new to the Forum I have a Harfield Matrix 2U 1000 Amp Bought in 1993 and I have been looking for a service manual or schematic for ages without any luck. One channel blew up. do you have any links were I can search please. Sam. |
