Has anyone heard an all valve rig e.g. Axis, S&P? |
Post Reply | Page <1 56789 11> |
Author | ||||
Roman
Registered User Joined: 01 April 2017 Location: New Zealand Status: Offline Points: 66 |
How do I prevent damaging my JBL 2245H's with too much power?
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
Now that is lovely. Just out of curiosity,i see you have added a fan,what is approx. life expectancy of the valves in something like this? |
flinnt45
Registered User Joined: 30 April 2013 Location: london Status: Offline Points: 111 |
Two fans actually the way these are run maybe 10years
JAH Kreator Hi Fi
flinnt45
Hi Roman choices re speakers i cannot advise
JAH Kreator Hi Fi
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1780 |
Thanks. I wonder if the amp was built by a man called John Chambers. Several were built a few years ago. He's not the only builder tho. Edited by valve head777 - 24 February 2018 at 3:15pm |
flinnt45
You mean the amp in the picture ?
JAH Kreator Hi Fi
valve head777
No, I know that's your beauty.....
John built some 1k mono blocks a number of years ago, can see pic's on the web, using 813's afaik. Edit.... Got valve number wrong Edited by valve head777 - 24 February 2018 at 4:05pm |
Roman
When it arrived in New Zealand. Apparently it didn't work. It took a bit of rebuilding as I understand it. The buyer was disappointed. So the builder isn't respected.
valve head777
Not Mr Champs then, because he is respected. Was the designer for some guitar amps dating from the 60's. Maybe, if you are interested in valve amplifiers, Google John Chambers.
Why get one from England if builder available from NZ? Valve amps tend to need maintenance input to keep them running sweet. If the amp your mate bought was fundamentally flawed via design, then yeah, resect lost. Sorry to hear of your disappointment. As said by others, valves need dedication. You could get an equally vintage sound via old design MOSFET amps. Mofets also have some ofthe characteristics of valves. I also own Mr Eddie early mono block mosfet amps, and when pushed sound fantastic. Did you check the track I was on about earlier?? |
Roman
You mean John Holt's ali baba? Yes
Would I compromise sound quality by not using a reggae pre amp? I want to plug everything into an Allen and Heath Mix Wizard 16 channel mixer. I would utilise fancy tube phone pre's outputting line level to the mixer. The mixer would feed a crossover and the 4 way crossover over come back into 4 mixer channels that wouldn't be assigned to the master bus feeding the crossover, thus avoiding feedback. But outputting directly to the amps. Clever eh! Then I would have heaps of channels for mic's, effects and 8 track multi track audio for dubs like Mad Professor does. And of course I could control the crossover levels from the faders. Or maybe this is unnecessary if I just adjust crossover levels on the crossover? I wouldn't want to accidentally press the 'master bus' assign switches on the crossover channels creating a feedback loop.
valve head777
Can be done that way, just depends on your own preference.
sometimes known as a ghetto pre. Nobody has to have a reggae pre-amp |
Dub Specialist Sound
Great replys , info and reasonings
Superb!!! thanks all
