HD 15 Curve |
david ![]() Registered User ![]() Joined: 08 May 2009 Location: barry Status: Offline Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: 13 August 2013 at 5:02pm |
Has anyone made a hd 15 with a curve?
I have managed to by laminating ply up with the correct curve. But as there is a lot of grain in vertical direction not curved strength over time may be an issue. Just wondering what others have done I'm contemplating fitting a layer of fiber glass between lamination or making the entire curve out of GRP not sure on the amount of flex that would be present. Any ideas? |
nuclearbass ![]() Old Croc ![]() ![]() Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
had mine for about 3 years now, and they were "well used" when i bought them..
The curves fine |
one life - have fun!
Force fusion pro audio |
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7363 |
http://www.speakerplans.com/index.php?id=daveyhd15
http://www.speakerplans.com/index.php?id=domhd15 http://www.speakerplans.com/index.php?id=vitorhd15 plenty more build threads about the forum... don't be afraid to search. ![]() |
njw ![]() Old Croc ![]() ![]() Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2529 |
Here are my efforts;
![]() I built those about five years ago and they've seen plenty of action since (the picture was taken recently) and the curves are absolutely rock solid, I think the trick is to use plenty of glue between the laminates and plenty of clamps whilst it dries so they hold together solidly, also, remember, even though you're layering up the thinner pieces of ply with the grains all running in one direction there are still going to be laminates within those layers running in other directions to give you strength, not to mention curved shapes tend to be naturally strong anyway.
