  New Posts New Posts RSS Feed - HD 15 (handles + time delay)
philip banyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Topic: HD 15 (handles + time delay)
    Posted: 26 November 2004 at 11:13am
HD 15
Where do I put the handles?
I guess in the speaker compartment I would then seal with silicon sealant.
Time delay 2nd question, my midrange is just a normal box with 2 12s old fane design
This stands about 1 meter above the HD 15 box, so how far forwards do the HD 15s need to be placed in front of the midrange. (or is this behind)
I also have the Behringer dig xover but have not tried jet automatically time delay.
Is this easy to do, and is it any good.
Sorry for the dumb questions.
 Thank you for all the help you all give with your replies.
PBanyer
dubsuction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 11:34am
hi!
....for the handles, i think you need to do as you said, cut out holes for the handles then seal, if you can find dom ask him as he's the HD15 master!
as for time delay, they need to be moved IN FRONT of the mid/tops by the same distance as the horn length....in HD15 its not too long, maybe 50-60cm (never measured one) .....dom?
hope it helps
peace+respect-always
**HIGH PRESSURE SOUND SYSTEM**
www.highpressuresound.co.uk
Dave Slater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 1:45pm
you'll find bar handles will fit nicely just behind the speaker
as for delays you need to delay the tops not the bass
horn driven bass will always take longer to reach the front of the pile than anything else and you to pull everything else back to take that into account
you need to work out where in terms of distance from the stack you want to align them for (suggest 6-8feet)
measure the distance from your HD15's to the ears of the average height person and add about 85cm for path length
now measure the distance for the tops and subtract that from the total for the HD15's which gives you the distance in delay you need to add to the tops to push them back into alignment with the HD15's
to fine tune it invert the HD15's and play a test tone at the same frequency as your crossover point and play about with the delay setting until you hear it go as quiet as possible flip the polarity of the HD15's back to normal and hey presto your rig is now time aligned
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 3:09pm
To save you the trouble (unless you set it up automatically using your LMS) i did it with mine on Wednesday -  5ms
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 3:12pm
Oh, dave, surely with that method, if you miss the first phase of cancellation it's possible to go a whole wavelength out.  Suppose it's good to check the numbers are reasonably what you expect
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 3:39pm
yeah if you're daft enough to keep winding the dial 'stead of going back the other way
if you go too far in one direction you'll hear it getting louder as the two boxes sum their outputs together with the HD15's being inverted they are in phase at this point but if they were running normal you'd have reached the 180 degree out of phase mark
you should be in the right ballpark with 85cm path length (shorter if anything) on the HD15's but doing it by ear and measurement not automatically you can't account for any group delay off the tops unless you fine tune it like this
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 4:02pm
Quote yeah if you're daft enough to keep winding the dial 'stead of going back the other way
Hey in my world anythings a possibility!!
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 7:36pm
That actually sounds a bit out...  5ms is 1.7m, which is about double what you'd expect (in fact almost exactly double), and more like the horn length of an 1850 Horn...
I wouldn't trust the results you get from auto setting on an LMS, especially a behringer one
Even SMAART gives really odd responses unless you use pulse tones the same frequency as your crossover settings, as you get the delays from the crossover as well...
We used the sine wave method when we brought the rig down to that barn party (no it wasn't some crazy experimental techno we were playing) and we were only ever a couple of cm out at each crossover point with our initial guesses based on horn length(Superscooper 2.2m, HD15 85cm, MT12 55cm, 2" 25cm, slots 5cm)
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2004 at 10:10pm
Yeah, i shouldn't have posted that really, it was a hazy memory from wednesday night (it had a 5 in it...ummm) and i had the speakers set up in a funny way so it wasn't a traditional setup by any means and to suggest that my delay will work for you is, frankly ludicrous!  *slaps wrist*
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2004 at 7:38am
Quote Even SMAART gives really odd responses unless you use pulse tones the same frequency as your crossover settings, as you get the delays from the crossover as well...
True. Testing in the middle of the passband makes sense.
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2004 at 1:32pm
HD15 handles, best recessed so that the screw heads are below the surface, get much less scratching of the cabinets.
I've tried auto delay on Behringer and got some wierd results.  Any guru's?
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2004 at 8:13pm
Yeah, use your ears....  They don't tend to get confused so easily...
It's not like you have to it to do it all the time.  You only have to work out the delays for each box once.
