hd 15 mitre |
jungle
Registered User Joined: 30 June 2007 Location: United States Status: Offline Points: 11 |
Posted: 23 July 2012 at 12:53am |
good afternoon guys. i have been coming here for years but i think this is my first post. i started building my hd 15s. but i just ran in a snag. i do not know how to cut the angles over 45 degrees because my saw only goes to 45. i have read all the post on here. any help would be greatly appreciated.
thanks in advance |
Timebomb
I made a 90 degree block that clamps to my table saw, and fed the piece of wood through vertically.
ceharden
Or if you have no other option, cut it at 45deg then use a plane/sander to get it as close as you can.
ceharden
Are you just talking about the corner piece (top right of side view). If so, I would be tempted to say don't worry about it. Cut it at 45deg both ends and be done with it. It's so close I doubt it'll make any significant difference.
jungle
yes i am talking about the corner and the baffle angles.
jungle
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
+1 for what ceharden says, when I built my HDs I wasn't too clever with the table saw so i cut the corner pieces at 45 degrees and cut the mitres on the baffle with an electric planer and they turned out fine.
jungle
thanks allots guys i will try and see what i can do with the baffle. wish me luck.
Neurosub
Registered User Joined: 22 December 2010 Location: Canada Status: Offline Points: 23 |
for the corner piece it has to add up to 90 degrees.
I just made 2x HD215, and i did one at the proper angle and I did one at 45 / 45. Can not tell difference. The true angle is 40 degrees and 50 degrees...obviously tapering out as the throat / horn must continue to expand as it goes out the mouth... |
