HD 15 with Eminence Kappa Pro LF222 |
Sam0
Topic: HD 15 with Eminence Kappa Pro LF222Posted: 06 July 2020 at 12:01pm |
Hey, i have two HD 15 loaded with Eminence Kappa Pro LF 2. http://https://www.eminence.com/pdf/Kappa_Pro_15LF2.pdf - http://https://www.eminence.com/pdf/Kappa_Pro_15LF2.pd Has enyone tested this Driver in the HD 15? I have Problemes at some Frequences and don't know if i have the wrong Chassis inside. Is this Driver useable in this Cab or shoud i search for an other. Thanks a lot...
djeddie
Posted: 06 July 2020 at 4:17pm |
At the top of the HD15section is the 'HD15 Simulations', have a look through there and you'll probably find it. The main thing with HD15's is that they sound terrible above the 150-180Hz... they'll "honk". So what frequencies are you having problems with?
Tom66
Posted: 28 December 2020 at 8:36pm |
Yes that is exactly the setup i use for kicks, between 80 and 155 Hz. They sound great, and we've hammered them fairly often and they seem fine.
