  New Posts New Posts RSS Feed - HD Copy
HD Copy
chris_k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris_k Quote  Post ReplyReply Direct Link To This Post Topic: HD Copy
    Posted: 11 November 2008 at 10:47pm
A dealer local to me is starting to sell come cabs very like HD`s
It has two main differences.
1 There is no compression area.The curved piece just butts upto the driver baffle.
2. the back brace is curved.
Will they work without this compression area, is it essential?
Does the curved section (as opposed to straight) do much good?
They werent loaded when i saw them so couldnt have a listen. Gonna pop in with some pd1550`s and see what the sound like.
Edited by chris_k - 09 April 2009 at 8:36am
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2008 at 11:29pm
Dead
www.stableaudio.co.uk
Speaker Building Services
davey t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey t Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2008 at 7:00pm
the curved reflector makes no difference. ommiting the piece of wood which gives seperated the throat volume from the start of the horn DOES and WILL make a big difference. i'm guessing it wont go as as low or sound as good
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2008 at 7:10pm
I theory it won't go as low but it should also perform better higher up.  Might make it more of an 80Hz upwards kick bin rather than a 60Hz and up cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2008 at 7:24pm
does it not turn a band pass into a horn - a very short horn at that?
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2008 at 7:56pm
Looks definetly like it will go louder, throw further, with reduced sub. Taken away BP and made  a full FLH he has. Increase rear chamber to lower response.
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2008 at 8:03pm
By removing the front chamber he's made it into a single fold offset driver horn. You can model this on hornresp if you wish, there's a tool for it.
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris_k Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2009 at 7:49pm
Below is a rough idea
Well these cabs have seen the  light of day.
Pro Audio M-15 2000W Bass Bins PA DJ Disco Install
Price has gone up £200 since i saw them. Hope the build quality has gone up. Flimsey curved section, Wood screws securing access panel!Wacko
Edited by chris_k - 09 April 2009 at 8:37am
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2009 at 8:12pm
looking at the other cabs in the "range" it looks like they use Celestion drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris_k Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2009 at 9:15pm
Dont think they are Celestion. I was shown a couple of `their` drivers. 15" + 18". Looked very much like unbranded chinese. Cast chassis if i remember correctly
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2009 at 12:00pm
has no one noticed exactly who the seller is?
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris_k Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2009 at 9:01pm
Yes.........They do sell some sh*te. They are fine for odd bits and bobs in an emergency (they are only round the corner from me).
These are probably a step up from the piezo / skytronic / generic crap they sell.
This page was generated in 0.059 seconds.
