  New Posts New Posts RSS Feed - HD Copy
HD Copy
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2009 at 3:55pm
seems an odd product to rip off/push as it really isn't suited to the cheapo DJ setup. What are you gonna achieve with a couple of these - certainly not earth rumbling bass Confused
"these cabinets provide an ideal, all in one, flexible solution to your audio requirements."
Well so long as you have another 3 ways to go with it!
www.stableaudio.co.uk
Speaker Building Services
ultramars10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultramars10 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 3:15am
Originally posted by ceharden ceharden wrote:
I theory it won't go as low but it should also perform better higher up.  Might make it more of an 80Hz upwards kick bin rather than a 60Hz and up cab.
Hello,
i'm precisely interested in reproducing the 80hz-250hz range, since i have C-subs below 80hz and R2Sh above 250hz:
ommiting the piece of wood which gives separated the throat volume from the start of the horn is maybe a bit radical, but would it be an idea to reduce its depth by half in order to do such frequency range ?
Edited by ultramars10 - 17 May 2016 at 3:18am
