HD15 Driver Sims |
Page <1 23456 9> |
monkeypuzzle ![]() Young Croc ![]() Joined: 25 January 2005 Status: Offline Points: 864 |
Dave,
I've finally got to taking the back off my hd's and found that the drivers used are rcf L15L601's.
i've dug out the t+s for them and was wondering if you would be really kind and helpfull and stick them in the magic graph maker and model it for me.... i've had them running with PD loaded bins on a few occasions but never had enough time to do an a/b test. I like em, would love to see what the theory says!
Vas 190
Qms 6.6
Qes 0.32
Qts 0.31
Fs 38
Re 6.8
Cms 0.2
Sd 804
Mms 92
Bl 21.7
Xmax 5
Cheers, matt p
Strange Daze ![]() Old Croc ![]() Joined: 14 July 2006 Location: United Kingdom Status: Offline Points: 2861 |
they sound ace matt....
wanna see the specs and compare em to our fane loaded 4 too......
and biggins' eminence 600s......
philpope ![]() Registered User ![]() Joined: 21 January 2007 Location: United Kingdom Status: Offline Points: 41 |
where did the input screen go off the first post in this thread? Phil |
djshirish ![]() Registered User ![]() Joined: 19 October 2006 Location: India Status: Offline Points: 7 |
which is the best suited driver for the hd 15 horns?
would u recommed any driver from the selenium or the p audio range without compromising too much on the quality tht one gets from the pd154's??
DJ Vencenzo ![]() Registered User ![]() Joined: 20 May 2007 Status: Offline Points: 18 |
can u pls sim the jbl 2206J or the 2226J
zivanovic ![]() Registered User ![]() Joined: 09 July 2007 Status: Offline Points: 1 |
Can you simulate please EV 15B series II
mhtplsh ![]() Registered User ![]() Joined: 27 August 2007 Status: Offline Points: 112 |
Excellent post!
How about writing procedure & detail of hornresp simulation so that many can simulate the driver of their own choice. it will be nice learning for others. |
palesha ![]() Registered User ![]() Joined: 08 April 2006 Location: India Status: Offline Points: 50 |
Dave Slater,
Just want to know how u calculated horn length. Drawing will be more preferable to learn & understand. |
santou ![]() New Member ![]() Joined: 08 June 2004 Status: Offline Points: 9 |
hi, what the result whit beyma 15k200?
josh ![]() Registered User ![]() Joined: 03 December 2006 Status: Offline Points: 682 |
yeah im confused about some of the dimensions youve got there, my calculations, and im not saying im right are mostly different.
How did you calculate horn length, from where did you take it, also where did you decide the throat was? |
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5299 |
Right I might be getting four hd15 this weekend as a second rig.
Does that plot for the sn15b look doable? reason I ask is I can get these easily, I would use some kind of sub, either an x1 or a reflex to do the 30<60hz [ish maybey a heigher crossover, whatever works] for a small rig does it look like a good idea? Thanks Markk. |
mstep77 ![]() Registered User ![]() Joined: 19 July 2006 Status: Offline Points: 457 |
Tell you what, the plot for the SN15-B looks great to me. Its really flat so you can use one box per side if you want (of course with sub underneath).
You plan sounds good, I would be pleased if that was my A rig
Page <1 23456 9> |
