HD15 Driver Sims |
Page <1 45678 9> |
simo69 ![]() Old Croc ![]() Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1838 |
I have heard that they will work well in the hornloaded cabinets ... I have purchased one to try also.
Edited by simo69 - 08 July 2009 at 10:04pm |
http://sims-audio.co.uk/
jORDy ![]() New Member ![]() Joined: 28 July 2009 Location: Romania Status: Offline Points: 9 |
Can you please simulate this driver when you have some free time? These are his parameters:
FS - 40 hz
Re - 5.5 ohm Qes - 0.35 Qms - 2.63 Qts - 0.31 Vas - 190 L Sd - 839 cm2 Xmax - 3 mm Mms - 80 gr Bl - 19.2 Le - 1.76 Cms - 0.19 (mm/N) Rms - 7.96 (kg/s) Cheers.
jonny4288 ![]() Registered User ![]() Joined: 06 August 2008 Location: N.Wales (WXM) Status: Offline Points: 586 |
hi jordy,
i would recommend a driver with an xmax higher than that, 5mm and above will work well
Heh, it's a bit hard to find a driver with a bit higher x-max and don't jump over my budget... :(
tweeter box ![]() Old Croc ![]() Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Zollax ![]() Registered User ![]() ![]() Joined: 11 June 2008 Location: Sweden Status: Offline Points: 48 |
Hi :) I was wondering if someone could simulate the Fane Soveregin 15-600 LF
http://www.fane-acoustics.com/prod_details.aspx?pid=197 Would be very helpful :D //Zollax |
Carlos Alexis ![]() New Member ![]() Joined: 27 April 2010 Location: USA Status: Offline Points: 7 |
any idea of how eminence kilomax will do in this box? how many watts?
t.geessounds ![]() Young Croc ![]() ![]() Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
how about the kappa pro 15LF-2 is this a good choice for the hd??
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Fane Sov Pro 15-500
![]() ![]() Comments ASAP please |
sKs01 ![]() Old Croc ![]() Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
4.0 Pi for kick cabs lev, also I'm not sure if the simulation for the 154 is correct it should look like the one on the plans page of the main site, rog put up the correct input perimeters though i can remember where...
Edited by sKs01 - 12 May 2010 at 12:26am |
OK. Im assuming all the previous sims were based on 2x cabs on the floor hence 1PI, but raised above subs its 4PI? |
spot on, btw read the edited version of my post, i'm a bit knackered and on my way to bed. |
Page <1 45678 9> |
