HD15 Driver Sims |
Page <1 56789> |
tv00 ![]() Old Croc ![]() Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
PD.1550 SIMS Please!
How will it play in this box? |
simo69 ![]() Old Croc ![]() Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1838 |
Should be stonking!!!
DjLeco ![]() Young Croc ![]() Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 808 |
RCF MB15N401, can you simulate, please?
djwes99 ![]() Registered User ![]() Joined: 18 October 2010 Location: brighton, uk Status: Offline Points: 315 |
hi, just wondering if you could do a sim for the:-
Beyma 15p80nd
thanks in advance :o)
The needs of the many outweigh the needs of the few..... or the one.
vzummer ![]() Registered User ![]() Joined: 08 April 2010 Location: Belarus, Minsk Status: Offline Points: 21 |
Would be grateful if someone sims these B&C drivers, while I'm trying to learn Hornresp myself SPL responce, Excursion, comments... 15NA100 http://www.bcspeakers.com/product.php?id=161 15PL100 http://www.bcspeakers.com/PDF/PRD/15PL100.pdf AND, can anyone tell me how flat is HD15's response by ear? If given a sweep approx. 80-170 Hz. Unfortunately I don't have an opportunity to hear it in my homeland. Is there always 100-120 Hz bump? Which T-S params to bear in mind for more plain response? Thanks a lot in advance, awaiting for help. |
Pirlo ![]() Registered User ![]() ![]() Joined: 25 February 2010 Location: Germany Status: Offline Points: 244 |
HD15 is a "kick"-horn, so ya want the "boom" at ~120Hz, that's why it's a kick-horn!
![]() Just use ya eq. to "change" the frequences as ya want. |
Who the fu&k is Mr. Phanton, and why he has so much power!?
B.A.M ![]() Registered User ![]() ![]() Joined: 10 March 2011 Location: Scotland Status: Offline Points: 159 |
What would be the responce of the HD215? Same as HD15 or extended?
Still no
How will it play in this box? -somebody removed it from the list! why? -because it's stonking? |
from what i remember of the 1550 sim was that it was only about 1-2db higher than pd154, and most of the debates i have seen about comparing the two drivers, most people said that in their opinion it wasn't worth roughly double the cost, 2 hd15's loaded with 154's coupled up would obviously be better but obviously twice as big and heavy, and you have the cost of building an extra cab. I was having a conversation with someone just a few days ago about driver choice and high sensativity v's high power handling and xmax which is usually associated with lower sensativity, and also we discussed how now-days wattages are just going up and up to achieve the same end spl. He asked me again which drivers I thought were better, and I said in my opinion it often comes down to how big your van is and how big an audience you want to do, If you have a truck, use a larger number of bigger high sensativity cabs, if you only have a transit van (short wheel base) and need to do an audience of maby 1000 ish then go for a smaller number of cabinates with the new breed of drivers often handling about 1500w each cost after all modern amps are cheap, small and lightweight compared to carrying the extra cabs
They're not that expensive though it's £20 more a driver, not exactly double the cost, they sound very well too! -We use them in hd15 & tms-2
Yes, actually it does seem to be the case that very suddenly the price of the 1550 has dropped a lot! maby due to the new 1551 coming out? :s going back a few months it was the general consensus of opinion that it wasn't worth the extra cash, but I guess now it can be easily enuff justified. I seem to remember the 1550 is a little bit lighter, which should make moving them a bit more pleasant too :D
tehmalakai ![]() New Member ![]() Joined: 14 August 2008 Status: Offline Points: 2 |
Can anyone give me an educated guess as to how this MCM driver would work:
Datasheet: Thanks!
Page <1 56789> |
