HD15 Driver Sims |
Post Reply | Page <1234 9> |
ashnono
Registered User Joined: 11 March 2004 Location: United Kingdom Status: Offline Points: 443 |
obertons too if you get a chance mate.
Disco Stu
Old Croc Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
Nice one dave fancy trying some 12"s in there just for kicks? Stu |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
ouch images broken?
speed
Registered User Joined: 22 August 2005 Status: Offline Points: 18 |
can you simulate this please peavey 1505 ka |
Dave Slater
Registered User Joined: 28 February 2004 Location: United Kingdom Status: Offline Points: 373 |
as you wish... but you'd be better off with the 1505-8DT as it's got 4.8mm Xmax compared to 2.6mm (practically the same response for both so i couldn't be bothered posting another pic) having said that the continous rating is only 350W for either of them so you're not going to get much out anyways dave ps. more sims to follow i got side tracked... |
speed
than you ver mutch do you think dis driver work better in this horn as an vented box maybe an other horn is better |
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
Ummm, is this always a 'one HD15' simulation? If yes, why not using always four HD15? Who puts only one? :) |
muri
Registered User Joined: 26 October 2005 Location: Slovenia Status: Offline Points: 9 |
speed
dave can you posts the input parameter of the peveay please
Dave Slater
it was originally done to match the plot rog put up with the design 1 bin in 1/4 space which is the same as 2 in half space (what we use above one X1) unfortunately horn response won't allow multiple bins when the horn is sectioned like this but it would let you put 1 bin in 1/8 space to give you the plot of 4 in half space there's nothing to stop anyone using the horn dimensions and doing it themselves or am i being too lazy? |
Dave Slater
peavey 1505 KA |
muri
Hi Dave Could you please simulate the RCF L15P300 in the HD15. I have two speakers at home and I dont know would they be good for the HD15. here the parameters |
