  New Posts New Posts RSS Feed - HD15 Driver Sims
HD15 Driver Sims
 Post Reply Post Reply Page  <1 789
Butcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butcher Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2012 at 12:17am
can the hd 15s be used for a home sound system
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2012 at 2:15pm
Don't see why not. Probably best to ask your neighbours for their opinion as well though.
tthorsten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthorsten Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2012 at 2:32pm
Is there any Simulation or pratical experience with the RCF 15P200ak in the HD15 in stacks with 2 or 4  mostly and by 6 or 8 for louder applikations ?
Edited by tthorsten - 26 October 2012 at 5:44pm
www.tb-audio.de
LEVELchek www.levelcheck.de
SPL tracking
SATlive www.satlive.audio
best Measurementsoftware for Live People
DBlimits
www.dblimits.com
Isemcon EMX7510 measurment Microphon
Mrd999 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrd999 Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2012 at 7:52pm
I am using a pair at home on top of a pair of cubo 15's, collecting 2 more hd 15's later in the week
Have had a complaint from someone 4 doors away though, that was just ticking over.
What goes around, comes around
DiscernAudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscernAudio Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2013 at 4:45pm
Dayton PA380-8
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscernAudio Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2013 at 5:44pm
HD15 5panel version horn dimensions,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscernAudio Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2013 at 9:12pm
Curious as to why we are using conical segments instead of one exponential or hyperbolic segment???
The cross sectional area does not increase linearly on the smooth curved version
and on the 5 panel version, there are not enough segment inputs in horn resp
From my drawing above,
S1=580.56
S2=2599.3
Exp (or Hyp) = 62.17
(Can Modify T parameter with Hyp selected)
(May change S2 to be larger as should be calculated normal to path centerline
which was not done in the above drawing and should only be done [if im not mistaken] when flat side of horn is coupled with another HD or a boundary layer i.e solid surface)
Still sims realatively close to the conical segments, but maybe this is more realistic (especially for the smooth curved version!)
Thoughts??
Edited by DiscernAudio - 10 July 2013 at 10:40pm
zenith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zenith Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2013 at 9:05am
hey guys,
 any data for Ciare FXE15-4?
Artical Kulcha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artical Kulcha Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2013 at 12:56pm
Well if thay bang this in a home , yu can use anything yu like..Big smile
32true View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32true Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2016 at 11:26am
Who's thay? what a living room though 10/10
simo69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simo69 Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2016 at 11:18pm
i have 8 loaded with Eminence Kappa 15LF and they rock.. got the cabs from a guy on eBay. - 4:20 Systems
Edited by simo69 - 06 November 2016 at 11:21pm
