HD15 & G-sub time alignment/delay settings |
Alexdj2k
New Member Joined: 24 May 2013 Location: Swindon/Bath Status: Offline Points: 3 |
Posted: 20 May 2014 at 12:22am |
Evenin' all
I have a pair of 215 HDs (kappa lf) and a pair of G-subs (18xb) along with some reflex tops and have been trying to work out the correct delay settings, but without any appropriate software / sufficient knowledge i'm rather baffled. The G-subs are placed on the floor with the 215HDs ontop and the reflex tops directly on top of them (they're 4ft high alone). I was hoping someone on here may have used this set-up before and know what the best rough settings are. I know it can depend on room size and many other factors but as this is constantly changing and sometimes outdoors just a rough guide would be muchly appreciated. At the moment my xover settings are: G-subs @ HP 36hz - LP 91hz (24db Linkwitz-Riley) 215HDs @ 99hz - 180hz (24db Linkwitz-Riley) Tops @ 190hz - 20khz (24db Linkwitz-Riley) Cheers in advance guys :) AJ |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Thanks(2)
Theres a nice and easy but not 100% accurate way of doing it. Get the gsubs to play to 110 or the hds to 80 just for testing purposes.Get a around 90hz sine or pink noise wave.Make sure they are about the same loudness before starting to delay the gsubs.Invert the phase on either the hd or gsubs and start delaying until the sound gets quiet,when you find the most quiet spot flip the phase back and there you have it. This was all written here before and its a nice and easy way of doing it.
Alexdj2k
Thanks I'll definitely try that later this week :) Cheers!
