  New Posts New Posts RSS Feed - HD15 Measurements
HD15 Measurements
JulianDA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Topic: HD15 Measurements
    Posted: 24 July 2020 at 1:27am
Greetings!
Since I could'nt find any measurements of HD15 when my friend and I thought about building our first ones and since there are people asking for those over and over again, I decided to take some measurements before we sell our HD15 and post them on here.
We did measurements of 1, 2 and 4 HD15 loaded with Oberton 15B450 drivers in a parallel configuration. They were done in a field with just some bushes to the side (2 Pi) on the ground with approx. 3,5m distance from the stack. The Mic was the Beyerdynamic MM1 which is not calibrated for actual soundpressure, so just ignore the absolute dB-levels.
This is the result and some pics of the setup/measurement-conditions:
I hope these measurements can help some people to decide wether or not to build their own HD15 :)
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 5:30am
Hi Julian, great post! Thank you for sharing this. This is highly useful! It is lacking a bit of circumstantial information though, which would add greatly to its value. Amping, power levels......
 Could you also please add information about the processing? I assume you have had a high pass filter in place? If so, please add cutoff frequency and filter order to your previous post. This is crucial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 1:30pm
Hey Bob,
since I wanted to provide accurate frequency response plots, there is no processing involved. No EQ, no HPF or LPF, just the fullrange signal to one ampchannel of a T.Amp TSA 4-1300. I did not alter the gainstructure when connecting more Speakers in a parallel configuration (so its a load of 8, 4 and 2 Ohms)
I would assume the cabs got something in the range of 10W but i just made sure its loud enough for a good measurement. Like i said, the mic is not calibrated for absolute levels, so the 130dB have no meaning. I can just provide the relative difference in soundpressure when using 1, 2 and 4 cabs and the change in the frequency response :)
But if it helps: We used the Yamaha Steinberg UR12 audio interface connected to a DCX2496 (without any processing enabled) which itself was connected to the TSA 4-1300 with just one channel used. There where no changes made when connecting more cabs :)
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 3:38pm
Interesting stuff, thanks for posting the data. I don't suppose you measured THD % at the same time? You can certainly see the useful bandwidth broadening as the mouth area comes up. Rapid fall off at 80Hz due to horn length as any fule kno, hence great partner to X1 etc when aligned well.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2020 at 12:55am
A+
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2020 at 2:10pm
You are right, we did not measure the THD... but I would like to do that if someone can tell me how to accomplish this with ARTA as the measurement software.
But I will just measure it for 2 HD15, since we already use two of the drivers in our new horns and its such a PITA to put the drivers back into the HD15.
If you can tell me how to measure the THD, I can compare the HD15 to our new horn if this is interesting to you :)
Regarding the bandwidth broadening of the HD15, I would say that the effect of the bigger mouth area is probably located higher up frequency. In my opinion this effects reduces the ripples in the range of 150 to 500Hz. The "bassextension" down to 80-90Hz is achived by the bandpass effect of the frontchamber and shows just a little improvement with the bigger mouth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2020 at 4:34pm
Ah yes, not so sure about ARTA. Tend to use REW for this type of thing. Quick check of ARTA's manual online says it will do THD, doesn't seem too complicated. Investigating THD as a function of power would be interesting, maybe gives a clue as to why people think HDs can honk high up.
Yes fair point re. that resonance that is suppressed with increasing mouth area. It is an interesting one albeit a bit of a moot point as no-one would ever play the cabs that high. It could be related to the L/A relationship of the bandpass port. I wonder also if the presence of that resonance is another reason that people find HDs honky up in that region near 200Hz.
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2020 at 1:46pm
Out of interest JulianDA what horns have you replaced your HD's with and what was the xover freq used when they were part of your set up. Also based on your findings in general do you think you could make an educated guess on how HD's will perform based on physical attributes and drivers used. Its interesting to note that the bigger mouth has little effect on bass extension. I always seem to view HD's as a take on a 'Turbo' Turbosound so any variation in design, drivers defo have to be considered so is this design flexi enough for other drivers or is it just the 15B450
Edited by djkeet - 06 August 2020 at 1:48pm
Soundbite
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2020 at 2:29pm
Sooo...we tried to measure the THD but had limited success because of an less then optimal location. I will update you with the THD when we have time to drive to the location of the first measurements :)
We replaced them with my own design. You can see the development of it in this thread:
https://forum.speakerplans.com/15-horn-to-go-over-x1s_topic103148.html
The HD15 were used as kicks above X1 Subs and the XOver was set to LR24 at 71Hz and LR24 at 151Hz (71Hz provided a nice coupling with the X1s and above 151Hz they just dont sound right...i.e. the honkyness) But i cant tell you the delay and phase settings from the top of my head, sorry.
Regarding your other question, there are a lot of forum threads about suitable drivers, but i cant comment on that, since we just tested and used the 15B450 and were quite happy with them.
I dont know what you mean with the physical attributes, maybe you can elaborate that a bit more?
PS: The thing about the bassextension and the hornmouth isnt really that supprising. Any horn has its characteristic "base-resonance" which is dependant on its lenght. The lowest resonance is the quarter-wave-resonance of this lenght, so the resonant frequency has a wavelenght of 4 times the lenght of the horn. The hornmouth has to have an adequate size to ensure a good impedance-match to the outside world at this frequency. So if you put horns together that are to small on their own, you can get a better loading (more efficiency) down to that frequency. But below that you dont get much more gain, since the horns are still to short (to be exact, you will see the resonance frequency shifting a little bit lower, since the horns gain some "virtual" lenght because of the boundarys)
If you translate this to the HD15 with its roughly 60cm hornlenght you get a quarter-wave-resonance at ~140Hz (the wavelenght is 240cm, so 4x60cm). Below that, the bandpass chamber dominates the output. You can see this effect in my measurements, since the ripples above ~140Hz get smaller with more cabs, while the form of the graph below that frequency stays nearly the same.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2020 at 3:29pm
Great work.
I know you said the cabs don't sound right abve, 150hz, but the response graphs tell me , with right drivers, and smoothing eq, 70-300hz is acheivable.
I had authentic THL 818s, and I had them doing 70-500hz quite decently, with regular Fane 15B600s,  and the right shaping eq.
I was more interested in lower mid vocals, than thumping kick.
Edited by levyte357- - 06 August 2020 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2020 at 3:34pm
[/QUOTE]
What I was alluding to was variations on the same theme/other ppls designs. But if your noticing honking @ certain freq prob the design as gone as far as it can go I will look @ your thread with your own design cheers.
Soundbite
Kalle76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kalle76 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2021 at 2:41pm
Hi Julian,
i was building some HD15 on my own, but my measurements were really weird with the pd.154.
Could you maybe post your plan, so i can compare what crap i did there?
Did you damp the rear chamber or something?
Greetings
