  New Posts New Posts RSS Feed - Hd15 - my versioin
Hd15 - my versioin
 Post Reply Post Reply Page  <1 1011121314>
keilamym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keilamym Quote  Post ReplyReply Direct Link To This Post Posted: 25 December 2014 at 9:33pm
i've actually never measured my speakers..  after the holiday if you can tell me how to measure it, i'll be sure to share the info.. i think I'm going to load Kappas in it.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 December 2014 at 10:40pm
Or drivers similar to Fane 15B.
Sure someone here can advise on measuring cab freq response.
Edited by levyte357- - 25 December 2014 at 10:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 25 December 2014 at 11:24pm
Why do you need to measure it?
paulronanqed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulronanqed Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2014 at 12:35pm
Just thinking out loud, not too sure why anyone would want this one over a Cubo 15, the Cubo is an easier build (no access cover) and will likely kick lower. But then again I suppose it depends upon what you want it to do, and what, if anything, you have below and above it in terms of frequency cover.
Do your best and no one can ever call you.
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2014 at 12:41pm
Hd and a cubo?
why?
Speakers don't pay bills...but they do now
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulronanqed Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2014 at 1:03pm
More instead of, rather than aswell as .......my "this one over Cubo" was a bit misleading I suppose
Ps like the "speakers don't pay bills" love building boxes, but struggle to make 'em pay, particularly since I'm carrying a 1000Sqft workshop now.
Post Options Post Options   Thanks (1) Thanks(1)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2014 at 1:06pm
What's response graph of typical Cubo 15?
Point of this cab is more of the upper end than lowest kick.
Would imagine this cab will extend downto 70hz quite easily with right drivers, in multiples.
Plenty low enough, if used above subs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulronanqed Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2014 at 1:14pm
True Lev, I would imagine these above say an X1 stack, would likely cover low end and kicks well. I love the X1's, but seem to be limited when you start getting anywhere near kicks
PsyroE66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PsyroE66 Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2015 at 7:27pm
hi guys a complete newbie here but wondering how would a pair of cubo15s loaded with these eminence delta 15" act, some of the specs a little off but wonder how important it is to be on point http://www.bluearan.co.uk/index.php?id=EMIDEL15LFA
specs for cubo15 -
  • 15inch Drivers with
  • EBP of 100 or higher
  • Fs (27-45 Hz)
  • Qts (0.26 - 0.38)
  • Vas (150 - 300 L) / (7.4 - 11.1 ft^3). Where EBP = Fs / Qts
specs for driver:
EBP 75
Fs 39 Hz
Qts .48
Vas 241 l /8.51 cu.ft     fs 39/Qts.48 = 81.25
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2015 at 1:29am
Maybe if you started your own thread, instead of hijacking this one, someone would be pleased to help.
charlynch View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote charlynch Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2015 at 7:49pm
@ PsyroE66 check out the cubo15 thread on freespeakerplans I'm sure the deltalf's have come up before.
If you haven't already brought the deltas it might be worth reading the whole thread.
PuppaBB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PuppaBB Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 9:23pm
This kick looks similar...
https://www.facebook.com/photo.php?fbid=1558256324435656&set=ms.c.eJw9yskJACAMBMCOxL0S~_69MEPU7DJLFFARMyhy40LZSjQf0GfognpHayUMNeQ~-~-.bps.a.1478874172373872.1073741846.100007539097720&type=1&theater
www.facebook.com/PuppaFran www.facebook.com/CrucialRuler www.facebook.com/DUBFever
