  New Posts New Posts RSS Feed - Hd15 - my versioin
Hd15 - my versioin
 Post Reply Post Reply Page  <12345 13>
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2005 at 5:21am
fineshed constructhion
http://www.igolkin.com/soft/Tda-audio/images/steck-fas.jpg
PoteirosCorp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoteirosCorp Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2005 at 5:29am
Hi TDA, I download the LspCAD program; I've done some simulations with reflex boxes, and I am curious about how you simulate this with the Lspcad, (how you put the port??)
Cheers
MrZuarth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrZuarth Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2005 at 2:43pm
Sorry, I DO NOT SPEAK ENGLISHMAN
Bueno queria comentar, que posibilidad hay de hacer este diseņo del HD-215, pero para bocinas de 18", con bocinas Beyma Mod.18G50.
Yo tengo un bafle similar a este, pero veo que tengo que hacer varias adaptaciones... y correciones... pero diganme... como ven ustedes esta posibilidad de hacer una replica del HD-215, pero para bocinas de 18"
Deberas, alguien me puede decir , como anexar IMAGENES
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2005 at 4:16pm
Babelfish translation
Good queria for commenting, that possibility has to make this design of the HD-215, but for 18"horns, with horns Beyma Mod.18G50. I have a speaker similar to this, but I see that I must make several adaptations... and correciones... but diganme... as you see this possibility of doing one talk back of the HD-215, but for horns of 18" Deberas, somebody can say to me, like annexing IMAGENES
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoteirosCorp Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2005 at 8:22pm
Let me answer him in spanish.
Que tal, el HD15 fue concebido para el mid-bass, asi que no hay una ventaja en constrirlo con componentes de 18". Hay unos modelos de bafles similares, como el ES18 BPH de Staiper, tiene casi el mismo principio de Bandpass horn al igual que el HD15. Ese bafle tiene un f3 de 54hz.
Dale al buscador con ese nombre que te di y encontraras informacion. Y otra cosa, trata de darle al ingles porque aqui se maneja este idioma, hay gente de muchas naciones diferentes (holandeses, rusos, rumanos, italianos, ingleses mexicanos, etc...) y todos le damos al ingles aca
Saludos
PD. te voy a agregar a mi hotmail
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2006 at 9:31pm
any one want to work out the horn resp inputs for her then? so we can alll see wot drivers will work.
some one must be able to sim her up ....
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
jethdub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethdub Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2006 at 6:57pm
TDA.. with some time passed since you first posted this design, I was wondering if you have anything to report on its performance? I'm particularly interested in the high end response, how high can you play these boxes? Thanks, Jeth
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2006 at 9:56pm
i do like the possibilities of suicide mdf rigs made up out of these with some kappa 15lf or similar.....
23kwsound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 23kwsound Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2007 at 9:59am
Hi are demensions on those plans right cause the baffle only sits 20mm from back is that right
djslacka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djslacka Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2009 at 4:37pm
has anyone built one of these? they look good to me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2009 at 9:40am
there is a guy local to me with 4 of these sn15b loaded.
I liked em!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote djslacka Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2009 at 3:58pm
kl, how was he using them, as a kick bass bin? they could be a good hd alternative
Forum Software by Web Wiz Forums® version 12.02
