Hd15 - my versioin |
Post Reply | Page <1 1011121314> |
keilamym
Registered User Joined: 20 November 2007 Location: California, USA Status: Offline Points: 441 |
i've actually never measured my speakers.. after the holiday if you can tell me how to measure it, i'll be sure to share the info.. i think I'm going to load Kappas in it.
levyte357-
Or drivers similar to Fane 15B. Sure someone here can advise on measuring cab freq response. Edited by levyte357- - 25 December 2014 at 10:40pm |
MarjanM
Why do you need to measure it?
paulronanqed
Registered User Joined: 28 September 2010 Status: Offline Points: 55 |
Just thinking out loud, not too sure why anyone would want this one over a Cubo 15, the Cubo is an easier build (no access cover) and will likely kick lower. But then again I suppose it depends upon what you want it to do, and what, if anything, you have below and above it in terms of frequency cover.
Do your best and no one can ever call you.
KidCreole
Old Croc Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3600 |
Hd and a cubo?
why?
Mykey Wattco
paulronanqed
More instead of, rather than aswell as .......my "this one over Cubo" was a bit misleading I suppose
Ps like the "speakers don't pay bills" love building boxes, but struggle to make 'em pay, particularly since I'm carrying a 1000Sqft workshop now.
levyte357-
Thanks(1)
What's response graph of typical Cubo 15? Point of this cab is more of the upper end than lowest kick. Would imagine this cab will extend downto 70hz quite easily with right drivers, in multiples. Plenty low enough, if used above subs. |
paulronanqed
True Lev, I would imagine these above say an X1 stack, would likely cover low end and kicks well. I love the X1's, but seem to be limited when you start getting anywhere near kicks
PsyroE66
New Member Joined: 24 December 2014 Location: United Kingdom Status: Offline Points: 1 |
hi guys a complete newbie here but wondering how would a pair of cubo15s loaded with these eminence delta 15" act, some of the specs a little off but wonder how important it is to be on point http://www.bluearan.co.uk/index.php?id=EMIDEL15LFA
specs for cubo15 -
specs for driver: EBP 75 Fs 39 Hz Qts .48 Vas 241 l /8.51 cu.ft fs 39/Qts.48 = 81.25 |
levyte357-
Maybe if you started your own thread, instead of hijacking this one, someone would be pleased to help. |
charlynch
Registered User Joined: 24 September 2011 Location: Somerset UK Status: Offline Points: 188 |
Thanks(1)
@ PsyroE66 check out the cubo15 thread on freespeakerplans I'm sure the deltalf's have come up before.
If you haven't already brought the deltas it might be worth reading the whole thread.
PuppaBB
Registered User Joined: 09 January 2011 Location: Bilbao Status: Offline Points: 112 |
This kick looks similar...
https://www.facebook.com/photo.php?fbid=1558256324435656&set=ms.c.eJw9yskJACAMBMCOxL0S~_69MEPU7DJLFFARMyhy40LZSjQf0GfognpHayUMNeQ~-~-.bps.a.1478874172373872.1073741846.100007539097720&type=1&theater |
www.facebook.com/PuppaFran www.facebook.com/CrucialRuler www.facebook.com/DUBFever
