  New Posts New Posts RSS Feed - HD15 plans revisited!
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Topic: HD15 plans revisited!
    Posted: 24 January 2012 at 10:44pm
ok so have to looking into building some hd15's iv notices the plans are really all there. iv marked the plans with bits that are missing. the red circles are angles and the black boxes are distances. so what are the angles in the red circles and what are the distances in the black boxes? also does anyone have the plans for the hd15 with the 3,4 or 5 piece horn?
any help is much appreciated
Cheers
Adam
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2012 at 10:57pm
I'm also looking for the 3 piece plans. I've seen some on a thread but they were also rather un-detailed (I know you can work out alot of it by using simple mathematics but it would be reassuring to know that I'm doing something to the plan rather than what my crappy trig can figure out)
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2012 at 1:59pm
worked out the angles just need the hatch size
AUDIO HABIT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUDIO HABIT Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2012 at 2:01pm
Good job
Edited by AUDIO HABIT - 01 February 2012 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2012 at 2:38pm
thanks Thumbs Up
looking at it i guess you make the hatch size to what ever sixe you want deppending on the driver you use.
Tocooltom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tocooltom Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2012 at 3:25pm
thanks Thumbs Up
Or just make the hatch as big as possible without compromising anything else so you can use whatever driver you like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2012 at 3:30pm
yeah thats right, il get some dimensions later for a largest hatch you can make
duminku View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote duminku Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2012 at 5:29pm
hi do you now how many liters are the hd15 please thanks asap
32true View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32true Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2017 at 11:51am
Does anyone know the size of the hatch for the hd15?
njw View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2017 at 8:46pm
 As above, make it as big as possible without compromising the integrity of the cab, there is no 'fixed' size for the hatch. Also, even with the hatch as big as possible I don't think any 15" driver will actually fit straight in, the driver needs to be fed through the hatch at an angle and sort of flipped on to the baffle as you lower it in, hard to explain but if you've got a HD in front of you you'll see what I mean straight away.Smile
Edited by njw - 28 January 2017 at 8:48pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2017 at 9:14pm
+1Embarrassed
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
This page was generated in 0.055 seconds.
