HD15 vs modified es18bph |
Matty309
Registered User Joined: 13 May 2019 Status: Offline Points: 116 |
Posted: 20 July 2019 at 8:15am |
Hi all,
I'm planning on building some super bass horns to go underneath some kickbins. I like the hd15 plans but I had a thought of replacing the 18inch driver in the es18bph ( with a modified s1 and s2 to give higher compression ratio ) with a 15 inch driver. I run some sims and it has given a much more efficient response throughout the band with a peak at around 60-70hz giving the es(15)bph and much more intriguing frequency response with much more low end. Again that depends if I can take advantage of that extra low end with the super bass horns sat underneath... Any ideas on this plan ? I have got sims if people want a look. Any help would be appreciated! |
