HD15 Width increase to 580mm |
Post Reply | Page 12> |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 24 April 2012 at 8:55pm |
Mate wants a simple 15" Kick cab to build, that will suit his MT121s.
Can any of you guy's do the HR sim for HD15, with width increased to 580mm? Yep, I know chambers, horn mouth all increase, just need to see how a few drivers sim in it. Know about all the options, this is just an idea. |
djeddie
Why not add 2mm to the height and then turn it on it's side? Just a thought -> can't 'HornResp' on my Mac.
levyte357
Yes could do that, but never really been impressed by 50-70hz performance of standard HD15, so was hoping slightly larger chamber, with tufty driver might help. |
djeddie
Ah, I see where you're coming from now Lev.
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Why not add some negative expansion and then claim neos won't work in it?
Jokes aside, I thought you were on it with the sims Ray. Shirley, it'll work. |
levyte357
I simmed Fane Sov Pro 600lf in HD15 with throats/chambers increased by 20%. Comparison revealed slight increase in SPL from 60-120hz. Needed to hear what the "experts" think. |
Wrek0ne
Young Croc Joined: 10 February 2011 Location: Cambridge Status: Offline Points: 749 |
PD1550 Without the mod 4 boxes 4pi 1w@1m
PD1550 With the mod. 4 boxes 4pi 1w@1m Hasn't helped much gaining 1dB @ 60Hz . Also Dj Eddie you can use horn resp, get Parallels Desktop, simply opens a new window and launches the os inside it. |
Poll this!
levyte357
Just had a look at few plans around the net, and seem to have found what I need..
Forgot just how good, TDA's website is... |
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
do u mind share wat u found???
levyte357
Haven't decided yet, many options though.. |
Wrek0ne
What is the TDA website? I have seemingly never stumbled that deep into the rabbit hole.
Scratch that I have seen it. Edited by Wrek0ne - 25 April 2012 at 3:51pm |
Poll this!
djeddie
I went down the route of tri-booting via Bootcamp (OSX, XP and Ubuntustudio) so it means logging out, restarting, HornResp'ing, logging out and restarting again! I should have done Parallels from the start. Oops. |
