HD15 with HD18 |
dj-holocaust
Registered User Joined: 24 May 2007 Status: Offline Points: 140 |
Posted: 09 January 2008 at 10:03pm |
anyone got any experience how this sounds?
Got 2 x HD15's and thinkin of gettin two used hd's loaded with 18" drivers any ideas. |
Mark James
no such thing as a hd18, there are similar designs though, errr, 15 id imagine would kick more hard, 18 would drop a tiny bit lower and sound probably warmer.........
what exactly do you want??? |
Mark James
if you already have 2 then id say get another 2 identical and stack them together,
by identical i mean as close as possible, especialy with the drivers....... two different but similar ish boxes will only sound bad to be honest... what are your hds loaded with??? |
Disco Stu
Old Croc Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
What music you play USB bins are essentially HD18 and drop deeper
Stu |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Mark James
but either stick to 18s or 15s, if you want two way get a sub optimised 18 to put below...
Disco Stu
What he said |
dj-holocaust
got hd15's at mo loaded with eminence :(.
Will stick to hd15's tbh I had a feeling that a bigger stack of same speakers would be better. Cheers for input. |
