  New Posts New Posts RSS Feed - HD15 with speaker waffle grills?
piers1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Topic: HD15 with speaker waffle grills?
    Posted: 08 June 2023 at 1:44pm
Anyone tried HD15 with heavy-duty speaker waffle grills?
Installed with rubber mounting gaskets on the front of the driver.
Will it be a tight and vibration proof?
Edited by piers1 - 08 June 2023 at 1:46pm
Esc4pe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Esc4pe Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2023 at 2:10pm
HD15 does not have an exposed driver?
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2023 at 2:15pm
That is correct, but you can reach the driver trough the horn.
The HD15 is in perfect height for that, in middle of my stack.
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2023 at 5:49pm
Put a full grill on the front or a smaller grill down the horn near the brace. i.e. like the EAW LA400.... if you are in the UK PM Markie, he is the forums goto guy for custom grills:
Edited by APW - 08 June 2023 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2023 at 9:39pm
Thanks for the info. I would like to hear from HD15 owners,
if anyone have, an experience with the grills mounted direct on front of the driver.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2023 at 9:57pm
markie has pretty much retired from grill making.
I don't think they're necessary for hd15s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2023 at 4:11am
Grills are not “optional” after damaged drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2023 at 6:44am
has it happened? I have run similar turbosound bins for many years now and never had someone reach all the way in to damage a driver.
clamps
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2023 at 9:18am
Do you mean installing such a grill on the inside of the baffle, between driver and baffle? Personally wouldn't do that. Someone malicious cojld still use a screwdriver or pencil or knitting needle to poke through the gaps of the grill.
Better install a grill at the throat, as indicated in the picture. This will most efficiently prevent anyone from getting near the driver to damage it. And you will not have the risk of your cone or suspension hitting the grill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2023 at 12:40pm
Yes, preferably grill on the inside of the baffle and driver.
But regardless of the grill position, I am more interested to hear if anyone out there have grills on HD15’s, if so what is the experience in regards vibrations and sound?
Edited by piers1 - 09 June 2023 at 12:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote piers1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2023 at 12:45pm
Most Turbo’s are a bit deeper than a HD15’s.
Just enough, to reach a driver harder.
Edited by piers1 - 09 June 2023 at 1:01pm
