  New Posts New Posts RSS Feed - HD215 with combined chamber.
Crazy Dane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 8:57am
Ermm Pd154 is the recommended driver for this cab, and the Lf15n401 Sims almost the same.
But I will take a look at what you recommend also πŸ™‚
Best regards... Frank
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 9:56am
i know, but imo the "original" Hd15 is not a nice cab at all. it has a brutal and unpleasant sound to me.
Same as every low qes driver in a BPH, after simming and hearing quite some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 11:18am
Interesting. I also think the pd154 loaded Cubo215 had very aggressive and harsh sound to it. But at the same time a really Nice kick.
You think the 15nlw9401 will deliver a more rounded and smooth kick?
What about 15lw2400? Looks to be just about the same driver, with ferrite and about 20% cheaper. Price isnt critical, but i dont need to save weight πŸ™‚
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 11:48am
yeah that is the ferrit Γ€quivalent and works aswell. not sure if the magnet fits inside the chamber, check that please ! ;)
It will be a smoother tone but still far from "washy" if you get what i mean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 12:13pm
Might be a good idea to check that πŸ™‚
Or else, neo must be the way.
I am mostly conserned about the strength of the cone.
I will from time to time be running a double on each side for small gigs. So it will be highpassed pretty "low".
So its not all kick duty. "sub" duty will also be needed sometimes.
Do you have any comments on the curved-to-3piece convertion? Or is it just all dandy and great that way? πŸ˜„
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 2:08pm
its a matter of looks. acoustics wise, 3 piece is totally fine.
15nlw9401 has carbon reinforced cone, iirc. way stronger than pd154 for sure.
You wont get usefull output below 60Hz, no matter what you put inside though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 3:31pm
I am thinking more about the measurements in the start of the horn flare where flare and front chamber meets.
It is not excactly the same, but very close.
About the driver, i think that should be strong enough then πŸ™‚
And Its actually the same price as PD154 when discount has been added.
I know 60hz isnt low low, and thats also fine.
If i need them to go lower, i will ad more. 2 stacks of 6 drivers each should make it a bit lower i guess πŸ™‚
Or else, if i really need some grunt, i will add some dual18 BR boxes.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 1:45pm
New user.. I have experienced some major problems with my e-mail and other accounts being hacked. So i have been forced to shut them all down and therefore i have made a new user here also..
Best regards..  Frank, now known as FOO.
Formerly know as Crazy Dane πŸ™‚
