  New Posts New Posts RSS Feed - hd215
hd215
Jahmateur View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jahmateur Quote  Post ReplyReply Direct Link To This Post Topic: hd215
    Posted: 27 February 2020 at 6:15pm
Salute!
Recently got my hands on a hd215 (double hd15 bin). As replacement for our ported kick bin we had.
Drivers don't fit yet, because a little error in cutting I guess. We can definitely cut out some wood next to the lid to make this work.
An other problem I now face, is that I don't really see where to run the wiring. Since the 2 drivers in 'seperate' bins, how would I connect this?
Do I put 2 speakon plates on the backside of the cab, then link the 2 drivers with a short piece of speakon cable everytime we play? Would look strange, but I don't see any other option other than drilling a hole through all the panels, but then you'd see a cable running through the horns of the bin. How did you manage this?
Also, since the cables will be running in front of the driver, do you fix them there in one way or another? I don't want the cable to be touching my driver in any way.
Looking forward to any ideas!
bless
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2020 at 12:03am
When i build the for customers i wire like the pic with red line...
i drill hole in the middle deflectors, then i run the cable along at the back of the mouth bracing, so it cant be seen,
to the next driver...pretty simple bro tbh...
the cable bit further down the than the actual red line , if yu get me bro
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jahmateur Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2020 at 3:38pm
So you also drill a hole in the plate where the driver sits?
Never had any trouble with the wire causing rattle against the driver or rattling because it's just in front of the driver?
Your builds are very beautiful! Love the cutouts in the center 'dividing' panel. Ours is full at the moment.
Will at the moment loa dit with beyma gt200 bc of lack of other drivers and some money at the time. For 200watt they do pack a punch, curious what that'll give
thanks for the response; Gwaan dub specialist!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2020 at 6:13pm
No bro at the rear, i router out the speakon plates, if ive understood you correctly bro..
2 examples
