Heavyweight amps still top dog for bass? |
Post Reply | Page <1234 7> |
Author | |||
JonB67
no worries,
Theres a section on forum home called "wanted" post your requests in there!
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Blimey, didn't know JTS had switched to Powersoft, not seen them for a while tho ... Spoke to K while ago and had a conversation around bs peak output for miliseconds not being suitable for reggae/dub. At that time he talked about bench tests and wasn't impressed. Still have love for his UA series amps.
levyte357-
UA series had great sound, but just not enough power for 6-8x 1850s. JTS driving 6x Redeye off K20, is apparently life changing experience!! |
valve head777
From where I reference from, if Tubbs is using that, then that's a very good advertisement. The crew I was involved with seriously tested Aba on bass more than once using UA.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
[QUOTE=levyte357-]Heaviest dub sounds in UK, WSP, Aba, Iration, JTS, all use Powersoft.
Something to think about. Are these systems heavier than the crest powered RC1?
levyte357-
Thanks(1)
August 24-08-2018, SCALA : WSP vs Aba vs Masaai Warrior. I took this pic, look at Amp rack.. |
levyte357-
WSP, Aba, JTS, Iration specialize in pounding you with 35-50hz sub, with approx 6x-8x Subs, covering 500-1000 people. So maybe different Arena to RC1.
Edited by levyte357- - 19 September 2018 at 3:03pm |
concept-10
How so? ive heard RC1 pound a few hundred people with 4 bins or 5000 people with 16 in exactly the same frequency band you are mentioning, iv'e also heard them shaking a building in the mid to high 20s.
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Consider the number of drivers in that stack of 16 subs
More than one I'm led to believe :)
Edited by Sinai Sound - 19 September 2018 at 5:22pm |
Beast
Registered User Joined: 20 June 2012 Status: Offline Points: 31 |
I have 4x McCauley 6174 (4r) drivers. The plan is that they are to be installed into some bespoke two piece folded horns with around 11feet of horn path (playing 25hz-80hz). The 3-4k was a rough guestimate to allow some headroom. They're serious sub drivers not common here in the UK. The main goal is control of cones, hence why I am looking for amps that are sub friendly. Above that will be 4x direct radiating 2206h per side from 80hz-500hz above that some BMS 2" neo coax's on jbl 2365a biradials. 80hz and up is being handled by Chevin amps. |
toastyghost
Well it's measured in seconds on the K series, so that's not really an issue. I guess trying it and doing your own research rather than just listening from what some other guy told you is better? |
Sirius Sounds
Registered User Joined: 19 March 2017 Status: Offline Points: 54 |
Those drivers would be a perfect match for Crest 10001 which would offer you double rms at 2 ohms. Check the spec.
