  New Posts New Posts RSS Feed - HEELLPP!!! Void Digidrive v2
ashleycornfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashleycornfield Quote  Post ReplyReply Direct Link To This Post Topic: HEELLPP!!! Void Digidrive v2
    Posted: 19 June 2021 at 1:46pm
Hi All!
Have had a Void Digidrive V2 running firmware 3.4.2 out on hire at some point last year and it has come back with an unknown passcode :-(. Does anyone know of a hard reset or a way of getting around it? We've got it to connect to Void DSP control software on the PC but it (as expected) wont let us access anything because of user permissions.....
Thanks in Advance!
Aman Gebru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2021 at 4:22pm
Press "GAIN POL and SYS" during power on and it should reset the password.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashleycornfield Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2021 at 7:30pm
Thanks for the reply, however there is none of the buttons you're suggesting on our unit unless i'm missing something. see link for the manual to ours.
Thanks.
http://voidaudio.ru/downloads/digidrivev2.pdf
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2021 at 10:24pm
If this is the Xilica Xp4080. Void didn't make there own units:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2021 at 10:07am
Ah ok, you have the later unit which wasn't an Xilica.
You have to reflash the firmware from the control software, you will loose the presets though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2021 at 5:48pm
Try entering the password as:
Factory
Using the front panel.
It’s been many years since I had to do this, so it might need to be all lowercase, all caps, or sentence case like written - or it might be wrong altogether - but that should let you access the unit as a hidden, higher level user than the normal one. You should be able to change the password there without losing settings.
This page was generated in 0.313 seconds.
