  New Posts New Posts RSS Feed - help Beyma mid/high speakers
gruka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gruka Quote  Post ReplyReply Direct Link To This Post Topic: help Beyma mid/high speakers
    Posted: 16 October 2012 at 7:43pm
May someone help i have bought the 4  beyma 15"MI 100 mid low spkrs with 2" beyma CP 800 Ti together TD 400 horn.May someone help and suggest for me the best trapezoid  mid/high enclosure design for two 15" inch with 2" inch driver on the centre mounted on the TD 400 horn. I would like to use for touring and would like to get more vocals for live performance.
I more satisfied with the bass am getting out of the four SB18 cabs loaded with 18p1200Nd driven by 4  synq PE 2400 at Bridge mode.
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 9:59pm
15 mids + 2" best go for bassreflex something like the x15
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 10:02pm
A bit of a "special" speaker this 15MI100. Efficient (light cone), but not much life under 100Hz.
Two speakers in a ~100 liter cabinet, BR tuned at about 80Hz and a 24dB/oct highpass at 100Hz would be my starting point. A 400-500 watt amp @ 4 Ohm, nicely limited at half of that, is about as much as they can take, to keep Xmax within spec.
Edited by Peter Jan - 16 October 2012 at 10:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gruka Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2012 at 5:54am
Just a reminder i would like to use them in a BI-amp three way system usuing dBx PA+ loudspeaker management system
thepersonunknown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thepersonunknown Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2012 at 9:21pm
i never did understand the 15mi100. swear by the 10mi100/250 in many cases and als the 12, but i have never seen a practical use for the 15mi100. it seems to be a 15inch mid driver with practicaly non of the qualities of a mid driver and even less of thoes found in a 15.
They keep telling me life is short, but its the longest thing ive ever done!!!
This page was generated in 5.547 seconds.
