HELP drivers wont fit |
Post Reply | Page 12> |
Men@work
Registered User Joined: 17 November 2005 Location: Great Britain Status: Offline Points: 89 |
Posted: 28 March 2006 at 5:01am |
Which is the best driver for the MT122 ????? Im just about to start to build a pair, When looking a the plan abit more closer, the rear chamber is to small to fit the recommended drivers, Speakerplans recommend the P Audio SN12B NEO Which is 152.00mm deep !! & the P Audio C12 300MB is 147.7 mm deep !! The rear chamber is only 148 mm deep ( on the plan ) The C12 300 MB will go but will it cool ok ??? I have been thinking of using the fane colossus 12MB 450watt or the fane 12 Classic 300watt, Which are not as deep and will give more clearance in the rear chamber ????????? Has anyone tryed the fane's with the P Audio SD 750N or the P Audio BMD 750 in the MT122 ????????? Cheers guys
Edited by Men@work - 28 March 2006 at 3:59pm |
At the end of the day its gets dark!! THEN WE PARTY
dubsuction
Registered User Joined: 18 August 2004 Location: United Kingdom Status: Offline Points: 269 |
hadn't realised that! i made a slightly bastardised modular version of the mt122 with the removeable rear pannel altered so it fits to the outside of the sides and top/bottom. the sn12 fits in here and they sound good i'm about to stick some wood inside the rear chamber to restore the correct volume. it also means that the rear pannel is easy to take on and off. might be an idea. cheers phil |
peace+respect-always
**HIGH PRESSURE SOUND SYSTEM** www.highpressuresound.co.uk |
Fushion Julz
Registered User Joined: 19 August 2004 Status: Offline Points: 647 |
Errr...I've built a pair exactly as per the plans with SN12B neos and they DO fit...only just, but they do....
Now problems (yet) with cooling either |
norty303
Yeah, but you were never much good with that measuring stick were ya.....
Fushion Julz
You talking to me, Norty?
norty303
Yeah, but it was a joke...
*Goes away to rehearse more* |
LunchieTey
Young Croc Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
Aren't the drivers rebated also? This might make up the difference and I'm sure adding 5mm to the design won't kill anyone :)
Speaker addict
Men@work
I dont think the drivers are rebated (as per plan) but it mite be a option has anyone tryed this ???? The fane colossous 12MB drivers are only 137mm deep would this be any benefit for cooling etc or would i have to put more timber in the rear chamber to keep the volume the same as per plan ???? Does the rear chamber have to be small as possible like the porn horn ?? Cheers guys
LunchieTey
One thing you may not have noticed with the SN12MB's is that the cooling vents are in the side near the spider so can have a rear chamber more or less touching the back
Maybe something 'someone' could do is perhaps list the hornresp input data so anyone can simply enter their driver details and see the result? Maybe a sticky on each(horn) forum? Then anyone can just see for themselves! |
Speaker addict
Men@work
Edited by Men@work - 01 April 2006 at 6:04pm |
Men@work
Edited by Men@work - 01 April 2006 at 6:19pm |
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
What you have to remember is the cab was actually originally designed around the PD123ER which is only 128mm deep...
