HELP ElectrovoiceT-18 Design |
Page <123> |
tb_mike
Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Posted: 01 October 2004 at 9:02am |
That t18 looks like a huge driver mounted on a very short horn-the horn might load about 50-60hz.
To add pics in the reply,they have to be hosted somewhere on the net . then try and see if it works.
Cheers! |
tb_mike
Posted: 01 October 2004 at 9:04am |
As shown by the PDF file its 100db/1watt at 100hz and much lower at 50hz.Its not a horn as such. Bite the horn bullet and build a real huge effective horn!
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 01 October 2004 at 9:26am |
Its more of a Half Horn enclouser, effictive tho,once i have loaded it with PD1850's!!! that will giv it more pressure,at the same time making it lighter to carry than a Full horn loadedcab. Four or six of them should be enuff 4 indoor venues, i have a Crown 5000vz amp sp that should power them oky. Just need to build the things!! Guys any sugestions on Bracing the internals, so that it will not fall apart wen loaded with PD's ??? What you think !! |
tb_mike
Posted: 01 October 2004 at 12:51pm |
Brace the weakest part
Brace the longest part that will resonate the highest Are u using ply or mdf? |
Rog
Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Posted: 01 October 2004 at 12:56pm |
But don't brace half way along a pannel. If you do you will end up with two panels that will both be radiating at the same frequency, but juts higher up. Put braces of centre to avoid making smaller but evenly sized panels. |
CHAMPION
Posted: 01 October 2004 at 9:39pm |
BRACE YOURSELF !! hahaha
staiper
Joined: 26 February 2004 Location: Croatia Status: Offline Points: 550 |
Posted: 02 October 2004 at 7:12pm |
JD01
Posted: 03 October 2004 at 1:40am |
The original drivers have a 2,5" VC, so it's no wonder that this speakers easily fry with 800W amping (clean, limited signal of course)....
tb_mike
Posted: 03 October 2004 at 4:56am |
Staiper-Good idea to make an msn group Perhaps if enough people were online at once we could discuss things in a chatroom-if we had enough
Cheers! |
Three Bee
Joined: 04 September 2004 Status: Offline Points: 11 |
Posted: 23 October 2004 at 1:09pm |
I dont know if its just me, but i cant draw the picture over on deltacad... The 45deg pannel at the top rear is always in the way of the 420mm brace. The angled pannels doesnt line up either if ya go with the pans... Anyone got a better plan / drawing?
Thanks Hugo |
Three Bee
Posted: 23 October 2004 at 1:10pm |
PS. id like the T18 plans though...
Three Bee
Posted: 30 October 2004 at 12:33am |
Anybody?...
Page <123> |
