Help Fixing a C Audio Pulse 2x1100 |
Post Reply | Page 12> |
H3ct0r
Registered User Joined: 08 February 2022 Location: Cambridge, UK Status: Offline Points: 11 |
Posted: 12 April 2022 at 11:12am |
Hello there everyone,
I am currently trying to fix a Pulse 2x1100 for my school and I am kind of back to square one. I thought that I had fully diagnosed the amp, ended up doing a swap on most of the semiconductors on the board, upgraded the IGBT’s and did a couple of the mods. After all of this was done, I isolated the power supply and powered it on, It seemed to run fine. I proceeded to connect the channels back up and powered the amp on, it seemed to run fine at first when all of a sudden, I saw a massive blue spark and both IGBT’s were split in half and my test resistor that I fitted instead of the soft start resistors got super hot. I now find myself with the same issue at the start, channel one tests fine with a multimeter and the output transistors on channel two are shorted, I have completely no idea on how to diagnose what the issue actually is and would need some advice from someone who has a bit more experience than me. Thanks in advance Br. Hector
Edited by H3ct0r - 12 April 2022 at 11:15am |
H3ct0r
If you need any more info, feel free to ask as I am very keen to get this amp back up
cravings
simonp1100 on this forum is the authority on these amps.. search his posts for wisdom, or maybe he'll appear and see this..
H3ct0r
i’ll take a look
kedwardsleisure
Did you replace the insulating washers on the channel output transistors? They can easily punch through at the bolt holes especially if overtightened or old ones reused.
Edited by kedwardsleisure - 12 April 2022 at 12:48pm |
North Staffordshire |
H3ct0r
I replaced most of them, i did also test between the case of the output device and the heatsink and it is completely insulated
H3ct0r
I have found his profile but I am unable to PM him, any chance that you would be able to?
APW
you need 10 points before you can PM, 3 or 4 more posts and you will then be good to go.
H3ct0r
ill reply to this in order to stack up some more lol
APW
only a few more to go...
H3ct0r
Let’s hope this one does it
H3ct0r
Dropped him a PM, hopefully I get a reply
