  New Posts New Posts RSS Feed - Help for Project: Horn OR 6 Order Bicycle 12V Sub?
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2018 at 9:21pm
I've been advised in the past to swap my MTH30 bins for reflexes, but every time I try to simulate something I end up with less sensitivity and output for the same sized, and often heavier, box.
Like I could load 2x bass-oriented 12" into a similar volume ported enclosure, but it would end up at least 1.5x as heavy and with only about the same available output when driven from my amps. The benefits would be proper response to 35-40Hz instead of 50Hz, and higher possible maximum crossover point, but those factors are less important than weight and sensitivity for me. I've got to be able to tow it a long way and the battery's got to last a good amount of time, otherwise there's no point in it being on a bike trailer ;)
