  New Posts New Posts RSS Feed - Help identify driver
Marko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Topic: Help identify driver
    Posted: 16 April 2009 at 10:39pm
I need help to identify this driver. I think it's JBL because wire contacts are the same like on 2225H but I cant find this driver on  JBL website. The horn is only glued on the driver so think it isn't original manufacturer combination. The driver alone looks like JBL 2426H, but without standard 1 3/8” -18 screw mounting. The horn looks like the one on JBL 2404H but the driver looks different. I will measure DC resistance tommorow and post it here. Here are a few pictures:
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2009 at 10:41pm
think its JBL to, they look a bit like the ones they used in the old SoundPower monitors,
CELTIC SUBSONIC SOUND SYSTEMS
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2009 at 2:24am
It's a Zomax or P-Audio. If the coil measures 34mm then it uses the 1034 diaphrahm, if it's 44mm it uses the 1044 diaphragm.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2009 at 7:54am
DC resistance of the coil is 5,7 ohms and the diameter is 34 mm.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2009 at 11:27am
zomaxDead
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2009 at 1:10pm
Zomax the poor mans P-audio, about 7 quid over here and sound it
Don't worry F$cked up bigger gigs than this one...........
