Help identifying amp builder + power ratings |
Post Reply | Page 12> |
dnbpc
Registered User Joined: 18 March 2010 Location: Manchester Status: Offline Points: 383 |
Posted: 07 July 2021 at 9:52am |
Picked up this amp this week and could do with some help identifying if it’s built by a pro builder back in the day or just a DIY job.
Also any ideas on rated power? Needs a good clean out when I get to the lockup at weekend. |
Pick & Mix Soundsystem
King Simeon
Young Croc Joined: 13 January 2007 Location: United Kingdom Status: Offline Points: 788 |
It looks like a JTS from 80's.
If it is, prob around 600watts power. I'll see if I can find out for you either way. Edited by King Simeon - 07 July 2021 at 12:27pm |
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Definitely a Tubbys, the (speaker) fuse rating might give a clue to power output.
Very reliable, should drive 2r, built by someone who absolutely knows the demands of a real reggae soundsystem. I owned one and have used several over the years. Probably 1kw judging by the transistor output count
Edited by valve head777 - 07 July 2021 at 2:35pm |
dnbpc
Wicked news, I took a punt on it to be fair never expected to get a piece of soundsystem history.
Speaker fuse is rated at 10A. Is it a mono block with 6 outputs or are there several channels? Also anyone have an idea where I could get a replacement fuse holder?
valve head777
It's a mono block amp. Nice piece to get hold of..
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1110 |
Looking at the heatsink, i assume there are two heatsinks with 4 MOSFET's per heatsink ?, looks like the standard 2SJ50 - 2SK135, so if there are 8 MOSFET's in total, this would give a max output of 400 Watts.
valve head777
Mine, which was rated at 1k, had 4 heatsinks. But this looks older and could well be a lower power one.
dnbpc
That’s a shame that it’s not got a bit more juice but should do a nice job of powering the quad 8” box I've built for the basement for house parties.
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 397 |
It should do about 550W into a 4 ohm load- dependent on the PSU transformer being man enough - but it will do that as a solid continuous output. If it is all working properly should sound very nice indeed.
Earplug
Pop in one of these:- And you'll have your 1k! |
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 924 |
If you can get a meter on it, measure the rail voltage coming out of the transformer.
simonp1100
The 2SJ50 & 2SK135 are + or - 160V MOSFET's at 100 Watts dissipation so you may get a little more & it also depends on the secondary DC voltage rails as well, again as someone else has already said can you measure the DC supply rails ?.
