  New Posts New Posts RSS Feed - Help me design a mid top speaker for my system
DiegoALM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiegoALM Quote  Post ReplyReply Direct Link To This Post Topic: Help me design a mid top speaker for my system
    Posted: 21 September 2023 at 5:01pm
I have built two tham12 loaded with the box 12-280 8 w and I have two tpa3256 amplifiers and a 36V battery as well as a mini DSP and an adau1701 from wondon.
My tweeter is a Selenium D220ti and an H6512 waveguide, the problem is that I only have two Lavoce WSN102.00 8ohm tp use as mids. and I don't know how to use them to reach the SPL of the Tham and the tweeter because I don't want to spend more money on drivers.
 I also have 15mm plywood. I know i can put the two midranges in vertical in the same box but i have read that using more than one midrange causes a lot of dispersion problems, can you think of any way I can do it? a V-shaped box or a mid-horn?
Edited by DiegoALM - 21 September 2023 at 6:26pm
fudge22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 7:34pm
Yes, multiple drive units covering the same frequency range will interact with each other, which can cause the response to change as your position relative to the speakers changes. Unless you can achieve the desired output with a single drive unit there is not much you can do.
Your main problem is not so much the 10” drive units, but the compression driver and horn. The horn/waveguide, is fairly small, and the drive unit has a recommended crossover of 1.6KHz. For better results, the crossover should be no more than about 1KHz or even lower (which your drive unit can't manage).
I would stick with just a simple enclosure similar to the X10 shown on this site. Obviously, you will need to retune the cabinet for your particular 10” drive units, but they will at least give some useful output up to the crossover frequency.
Unless the journey is the destination; i.e. the design and building is what you are into, I would not recommend using angled baffles or horn loading. The raw response is not good, and requires processing to get a flat response. Also, the output drops off significantly above 1KHz so you would need to be crossing over to the compression driver at no higher than 800Hz – 900Hz, preferably lower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiegoALM Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 7:57pm
Thanks for the help. Do you know of any compression motor for PA that can go lower and is not very expensive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 9:49pm
The X10 design specifies the Paudio 740N. I think the N stands for neodymium. The same driver is available with a ceramic magnet (BM 740), which is about as cheap as it goes. Presumably a reasonable number of people must have used them to be able to give an opinion. I’ve got some of the original BM 750 drive units, which are basically the same but with a 2” throat as opposed to 1.4”; I cross them over at 900Hz @ 24dB/oct. For the price they work well (My comparison is with B&C, RCF and Faital Pro drive units). I use custom built horns, but a quick check on the internet would suggest there is a greater choice of horns for 1.4” drive units than 2” so probably the way to go.
My experience with commercially available horns is limited, but go with one that is close to the width of your front baffle, which will be around 30cm with 10” drive units. Stay away from the narrow letterbox style mouths and get as close to a square as you can. If you are restricted on the overall height of the cabinet that might restrict things a bit, as could be availability where you live.
Before going out and spending more money, try the compression drivers/horns that you have. If you have an upgrade path in mind just design the front baffle (and cabinet depth) to accommodate  the new horns if you do change them.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 9:51pm
look at 1.4" drivers. eg FaitalPro HF146
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2023 at 3:02am
The Faital Pro are undoubtedly fine drive units, and are my current personal choice, but the HF146 is twice the price of the Paudio driver. I suppose it depends on what you consider not very expensive. In my opinion the Paudio are better value for money.
If DiegoALM has limited funds, I would still recommend building a system using the components at hand. The decision to upgrade, if necessary, can be made later.
