  New Posts New Posts RSS Feed - Help Please !!
Help Please !!
kick-spill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kick-spill Quote  Post ReplyReply Direct Link To This Post Topic: Help Please !!
    Posted: 11 March 2010 at 3:01pm
hey, can anyone tell me if this would be a decent system for house party's.
bass - Behringer Eurolive B 1800X PROkick - HD-15
mid/high- JBL JRX 125
also, could i power the HD-15 and the JBL of the same amp?
thanks. Ian :)
mrchay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrchay Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 3:06pm
The high/mid will be taken care of by the JBL's.
If you have the behringer prokick18000 whatever then I dont think you need HD15's as well, just leave it at that.
You will need two amps, and an active crossover.
1 amp for bass, 1 amp for mod/tops. The active crossover splits the input signal (from your ipod decks or whatnot) into bass output and mid/top output.
the system you suggest would be an expensive way to go really unless you have it all already.
You would be much better off buying second hand proper party kit on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kick-spill Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 3:18pm
Thanks for replying. :)
I new i would need a crossover, just wondered if you could run different speakers on one amp.
I all ready own the bass, i just wondered of a HD-15 because i would mainly be playing d&b.
What would be a cheaper alternative to the jbl125?
what could be a cheaper alternative for the mid/tops?
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 4:29pm
Sure you can, amps channels are independant. Put the mid and high signals into different channels and wire to cabs appropriately.
You won't need a JRX125 to keep up with that, a 115 would be adequate. In fact I wouldn't bother with a 15" mid driver as the HDs will reach that, a 12" would giver better midrange definition. Only advantage of the 15 is that it would (perhaps) handle lows better without the HDs. From experience the JBLs on their own need a good 8dB of low pass boost to meet the HF with any conviction for dance music especially.
Sack off the Behringer sub and build 2 HDs. I used to have exactly that stack in my old living room for a while and used it for a house party or 2. A proper management system instead of a cheap analog crossover and as a bonus a good 31 band EQ will yield more than acceptable results. Two HDs off one amp channel and a mid/top off the second would work.
If you need more lows then EQ the HD's, you limit the overall power handling before excusion at these frequencies (probably) but how loud can you get away with for most house parties anyway?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kick-spill Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 5:44pm
Yeah that sounds pretty good although don't have any experience at making speaker's
but im pretty good at wood work and have a few power tools.
my house party's are normally in the cellar.
so pretty loud but just try not too piss of the rents haha :)
would this eq be suitable ?
http://www.dv247.com/studio-equipment/behringer-fbq3102-graphic-equalizer-feedback-detection-system--21179
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 6:15pm
Worry about EQ last of all, it's a nicety not an essential (although some may disagree).
Post Options Post Options   Thanks (0) Thanks(0)   Quote kick-spill Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2010 at 7:11pm
Thanks for the all help :)
I am probably going to build an x10 first, and in the future 2 hd-15's
Ian.
