help.. please!! |
Page 12> |
kr1sounds
Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
Topic: help.. please!!Posted: 31 August 2014 at 12:42am |
ive looked around (maybe not hard enough), looked at sims and i've looked at modded versions &plans of this cab but none of them can play the range that im looking for.
i need a kick that will play 60-250hz with ease (15") to go above scoops any suggestions? hit me with it
fostonshfs.webs.com |
djeddie
Posted: 31 August 2014 at 1:05am |
Getting above 150 - 180 is the hard bit with BP horns... but Turbosound did it. Have a look for the TSE115 (?) cab. I'm sure that's what it's called. The plans are on the 'net, but you have to look for them.
kr1sounds
Posted: 31 August 2014 at 1:07am |
http://www.opf-verhuur.be/TURBOSOUND%20TSE-115%20BASS%20500w.htm <that?
djeddie
Posted: 31 August 2014 at 1:11am |
That's the one.
kr1sounds
Posted: 31 August 2014 at 1:16am |
now to find the plans (sigh)
kr1sounds
Posted: 31 August 2014 at 1:23am |
![]() ![]() found this but im not too sure if the hr response is correct. if anyone can redo it by using the plans if possible would be great
Sypa
Joined: 21 February 2013 Location: Croatia Status: Offline Points: 953 |
Posted: 31 August 2014 at 4:29am |
The sims dont matter really much if they show it plays 200+ flat its how it sounds doing that.I have tms-2 with 15" that plays 60-250 and it sounds good i think doing it :) The plans shouldnt be hard to find for tms2 kick section or tse115,you should focus more on getting the right driver for it.
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 31 August 2014 at 1:32pm |
Do you run it 60-250hz yourself ? Which driver do you use? |
Sypa
Posted: 31 August 2014 at 5:03pm |
The driver is a original ls 1506 .Yes running them to 250,lower cutoff depends on the situation though.
siox
Joined: 26 January 2010 Location: Austria Status: Offline Points: 38 |
Posted: 02 September 2014 at 7:04am |
Maybe the Martin Audio F2B will work for you. I'm not shure if they play 250 flat - recommended xover point is 220 HZ. If you decide to build them use RCF L15-554k.
Regards, George |
kr1sounds
Posted: 02 September 2014 at 1:01pm |
ive brought it down to 200hz, just waiting on a reply with the tms 2 kick section plan
levyte357-
Posted: 02 September 2014 at 1:09pm |
Try this: http://hornplans.free.fr/turbo_bph238.html |
Page 12> |
