  New Posts New Posts RSS Feed - help.. please!!
help.. please!!
kr1sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kr1sounds Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2014 at 1:12pm
cheers lev, have you heard this cab play before by chance?
fostonshfs.webs.com
T-Bone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2014 at 1:27pm
Nice Turbo plans is there another driver like Eminence Kappa 15 LF sound good on these like the HD15's? Curious if any other 15" will work that's available here in the US? Thanks Guys!Big smile
BASS, how low can you go!
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2014 at 9:14pm
Originally posted by siox siox wrote:
Maybe the Martin Audio F2B will work for you. I'm not shure if they play 250 flat - recommended xover point is 220 HZ. If you decide to build them use RCF L15-554k.
Regards,
George
The F2B will easily reach 250Hz, if not higher... it's just you'll never see the plans. They're not on the 'net.
siox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote siox Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2014 at 10:21am
yes they are rated up to 250hz, it will just sound more "clear" if you cross them at 200 or 220hz.
they need some eq - but with the correct settings they are the best sounding kick filler i know.
regards,
george
Edited by siox - 06 September 2014 at 10:23am
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2014 at 10:49am
HD15 is cut down version of turbo box. Cut down in size & freq response.
Have heard these BPH 238 (Basically TSE115), but was not with optimal driver, or LMS handling delays/response smoothing.
However with correct setup, would expect these to eat HD15, with same driver/amplifier.
Edited by levyte357- - 06 September 2014 at 10:50am
