  New Posts New Posts RSS Feed - Help: The tuff cab is peeling off!
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:19pm
Like some of the posters above have said you need to be looking at the stinky, oily, solvent based paints. Phenolic is a quite a hydrophobic surface and it's impermeable so water based paints that rely on penetrating a bit won't be too happy.
I think your bet bets are either to remove the coating or to use a solvent based 2-pack paint. I don't see many positive leads though from a quick google search.
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:52pm
get them LineX’d...
penguinmediasolutions.com
midas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 11:05pm
Glue and carpet oh the irony....
Angelow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 1:48pm
COULD BE THE old aged paint, do not do it with black and white label for 6 years :) I order a little fresh
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 2:21pm
you need to remove the phenolic layer by sanding it down
NEVER use TEGO or Phenolic faced plywood. Paint ang glue will not stick to it.
Ex Nexus_3
