Help with driver characteristics |
Requiem
Old Croc Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1805 |
Posted: 15 December 2022 at 3:13am |
Hiya guys, i've come across this high power neo driver and while i've been in the sound game for a good few years now, I've never really delved much into suitability of drivers for certain boxes and driver characteristics and so on, talk to me about qms and qts and so on and ill give you a blank stare
I'm looking for anything someone can tell me about this driver from this spec sheet, initial impressions, what kind of boxes it would go best in, do any of these ratings immediately jump out as being good or bad and so on.. Drivers that it may perform similar to? Import time takes a good long while so I'd like to know what i'm kind of looking at before making any commitment. Most likely none of you will have used this particular driver so most of this will be best guess of course, I'm just hoping there aren't any glaring alarm bells ringing from this. It obviously needs a fair amount of amp power, for a start, and has a deep magnet so might not fit in tight chambers, apparently the motor force is really impressive. I'm sure ive seen ones that look just like it before in some of the golden formula paraflex kicking about (no paraflex arguments here please ) These readings were taken from a brand new, un-used driver apparently. Thanks in advance for any help Edited by Requiem - 15 December 2022 at 3:15am |
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
cravings
It's a b&c 18sw115?
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
If its anything except a 18SW115 from B&C, walk far away from it.
Besides that its a knockoff, the ts parameters are directly copied from the 18SW115's spec sheet. There is no way they would end up with the exact same ts parameters as the original 18SW115.
cravings
or could be some sort of branded oem?
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 566 |
there are a lot of chinese companies "copying" known drivers, this looks like one if it's cheap, and you want cheap, it might be worth a punt otherwise, watch out...
Requiem
Ok cheers guys!
