  New Posts New Posts RSS Feed - Help with G Sub
Help with G Sub
stevesbUT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevesbUT Quote  Post ReplyReply Direct Link To This Post Topic: Help with G Sub
    Posted: 06 December 2004 at 1:07am
I would like to build the G Sub. However, I have connections to get 18 Sound Drivers and Ciare Drivers.
How would the 18 Sound 18L1400 work in the G sub?  I would imagine that the port lenght would have to be adjusted?
Thanks
steves
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevesbUT Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 1:10am
In addition, I would like to lower the -3 db point to at least 30-35 hz.
Thanks
Steves
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2004 at 12:26am
You don't ask for much do you?  You want use alternative drivers and you want it to work better than the original design...  Good luck..
Have a look at http://www.eighteensound.it/BR218.htm which is 18 sounds double 18 reflex box plan.  -3db point is over 50hz...
