Help with Mrk/Driver Choice with Cow. |
Page <123> |
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10883 |
Can you borrow a Turbomax 1800i? PD1850s should be easy enough to come by… the reason I ask is that you should just knock up a prototype of each cab type and try them loaded. If you can swing over to Manchester in a van I can pass on the details of a place that does free MDF panels.
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Specs can be found here http://royalloudspeakers.com, Sd is approx 1220.
Then let us confuse him some more. The V18-1000 will sound great in everything, cheaper new than used Turbomax 1500, but best in Mk2 or Mk3, as its not really a scoop driver. ![]() Have personally heard drivers sound better than 1850 in medium chamber scoop, but in smaller chamber, PD1850/PD186 were ridiculous. Edited by levyte357 - 23 November 2009 at 2:24pm |
tweeter box ![]() Old Croc ![]() Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
OR
if ur strapped for cash then the Celestion 100w will do main in the box
another option would be the Fane XB for that beautiful warm rolling bassline
hhhhmmmm decisions decisions
SUFFERER ![]() Young Croc ![]() Joined: 20 August 2009 Status: Offline Points: 617 |
Ive got some used, approved but not abused XB's up for grabs... cheap as chips.
Autograff ![]() Young Croc ![]() Joined: 22 October 2008 Location: Sheffield , UK. Status: Offline Points: 1361 |
Money isn't an option when it comes to amps , if i go for 1800's , i buy two inf8's/5000vzs , if i go for 1850's i only buy one.
I was intending to buy/borrow one of each driver and build prototypes , just wanted to see what people's opinions where.
Liquid_Steel_Sessions
R8 Records |
£50 each??
If cash isn't an issue, then as someone else mentioned, what power supplies do your venues typically avail? Would have thought only corporate gigs regularily have 3phase or 64A feed available? Fact is, with Tmax 1800 scoops, you would find it very difficult to match 8x 1850/V18-1000 in small chamber scoops like Rens/ASS, driven by 2x Inf8 Mk2/MA5000VZ. If they were driven by 4x strong 3K amps in bridge, you definetly wouldn't have a chance, even on 32A supply. So choose drivers wisely. ![]() |
Most venues have 32A , if not then a few 16A's can be found.
The power isn't the main issue anyways , what Im really after is the right sound , which would be low-end SPL . Which IMO is found more with larger chamber Turbomax scoops , than tight chamber 1850/V-18 1K .
R8 Records |
mykey ![]() Old Croc ![]() Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Well then, go ahead matey, and let us know what happens.. |
Tekasis ![]() Old Croc ![]() Joined: 03 July 2006 Status: Offline Points: 6492 |
You sure you got that the right way round? as I thought many of the PD1850 haterz been saying the reverse of this for years!!!
**Heavy Weight-Line**
A home without books is like a body with no soul. |
Saul ![]() Old Croc ![]() Joined: 15 June 2007 Status: Offline Points: 5912 |
put the 1800s in shortman and compare to s118 with 1850, and you'll see what i'm saying. but otherwise, yes i agree.
Page <123> |
